Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
xr4i starting problem
Old Aug 29, 2011 | 09:19 PM
need4speed00001's Avatar
need4speed00001
Default xr4i starting problem
I am restoring an xr4i 2.8 v6 for a friend that has been standing.
I am having problems getting the car to run properly.I have fitted
a new fuel pump as the old one would only work with a knock and
a replacement metering head unit.
I can get the car to run if it is cranked over whilst i hold up the vacuum
chamber disc in the metering head unit but it dies as soon as i let go of
it.My question is what provides the initial vacuum to open the chamber
which then allows the fuel to flow through the metering head unit?
Any possible common faults causing this fault?
Old Aug 31, 2011 | 09:04 PM
cos 4x4's Avatar
cos 4x4
Have you got the vacuum pipe from the plenum to the metering head conected?
Old Sep 3, 2011 | 04:06 PM
need4speed00001
Yes the vacuum pipe is on.I have got it running now by richening the mixture
up quite a lot,so i guess it must have been drawing too much air that was
holding the paddle down.It is still running lumpy but i think that a little more
tweaking will sort it out.
Many thanks for the suggestion.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
