Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
problem with xr2
Old Mar 9, 2009 | 08:22 PM
valvulines's Avatar
valvulines
Default problem with xr2
Good, I am of spain and I`ve a xr2 mk2, excuse my English, the topic is today my car lost refrigerant liquid and I have observed where it goes out and seems that this hole would wear a screw
Old Mar 9, 2009 | 09:41 PM
javierant3's Avatar
javierant3
Hello! I am from Spain too. That "hole" is simply a plug similar that those of the engine block and head. Probably it has rotten inside. All that you have to do is to extract the old plug and put another one new. You can buy it in a car spares centreor a ford dealer. You have to measure the diameter of the hole and buy a new plug.
And now in Spanish!
Hola valvulines eso que dices que pierde agua es simplemente un tapon metalico que lleva el cuerpo del termostato. Se habrá oxidado por dentro y por eso pierde agua por ahi. Simplemente tienes que sacarlo del alojamiento y comprar uno nuevo. Tendras que medir el diametro del agujero y pedir otro de la misma medida. Para meter el nuevo simplemente limpia bien el agujero y mete el tapon nuevo a presion. Puedes echarle algun sellante si quieres pero no hace falta en principio. Ese tapón no creo que te cueste ni un euro comprarlo. Lo puedes comprar o en un concesionario ford o bien llevar la medida y comprarlo en cualquier tienda de recambios para el automovil.
Old Mar 10, 2009 | 07:35 AM
valvulines's Avatar
valvulines
OK, thanks
Old Mar 10, 2009 | 06:58 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
It would be easier to get another thermostat housing.
DAZZER
Sep 30, 2015 08:43 PM
mondeomark
Sep 28, 2015 06:28 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
