What dry sump kit
Old 21-08-2017, 07:33 PM
mattman1234
mattman1234's Avatar
Default What dry sump kit
As title really,any reccomendations,thoughts,do i need separate stage for turbo,or can this drain straight into the sump as standard ??.Looking at the turbo sport one,seems pretty reasonable price ?
Cheers all
Old 22-08-2017, 06:21 AM
lacey
lacey's Avatar
You don't need a turbo scavenge stage unless
Your turbo position is very low in which case
Gravity draining from the turbo can be a issue
You can drain into the side of the pan
Or even near the scavenge tube on the dry sump
Pan
I do the opi dry sump kits
If you have a google at some pics or go
On Burton's site you will see the turbo drain in the
Side of the pan
Old 22-08-2017, 06:28 PM
mattman1234
thanks,,will have a look
Old 22-08-2017, 08:40 PM
mk2cossy
mk2cossy's Avatar
Dan Lacey is your man
Old 31-08-2017, 04:41 PM
mattman1234
Does anyone have an opi dry sump kit on their setup ?,if so, could do with a measurent from the centre of the crank pully,to the furthest outer edge of the pump.
Cheers all
Old 01-09-2017, 10:04 AM
lacey
lacey's Avatar
If you add 125mm on the power steering pump mount face on the block
Then that probably a little more then you need
lacey
lacey's Avatar
It's probably nearer 105 mm than 125 mm
Old 01-09-2017, 10:15 AM
mattman1234
top man
Old 28-01-2018, 01:01 PM
mattman1234
I'm gonna be ordering my dry sump kit soon,opi,or turbosport,
The opi sump looks a bit bulky to me,but let to believe its a better type of pump,
decisions,decisions
Old 29-01-2018, 04:20 AM
mattman1234
Can the existing piston jet spraybar be re-used ?
Old 14-02-2018, 05:32 PM
mattman1234
Think this is the only place for the tank
Old 14-02-2018, 07:18 PM
mattman1234
I'm going to order some braided pipe / fittings to check routes and bends,I don't want to skimp on quality ,therefore speedflow "an" fittings are on the list.Are these the best quality,i'm judging on price here.
Old 15-02-2018, 06:32 PM
mattman1234
pressure relief valve turned up,certanly sterdy !
Old 15-02-2018, 06:47 PM
Caddyshack
Caddyshack's Avatar
Looks great, I would zircotec coat the down pipe and remove that wrap, you have such a nice instal I think it would benefit from the neatness and better heat management.
Old 15-02-2018, 07:19 PM
mattman1234
Thanks,,a new exhaust is on the list of things to do first,have looked into the coating before,but ŁŁŁŁ ,its on the limit for track days
Old 19-02-2018, 07:34 PM
mattman1234
Took of the sump tonight ,to try and figure out a way of re-routing the spray jets with a dry sump pan.
Look what i spotted
see if anyone can see it:-
Old 19-02-2018, 07:39 PM
Caddyshack
Caddyshack's Avatar
Arp nuts or what is written under the piston?
Old 19-02-2018, 07:50 PM
mattman1234
Old 19-02-2018, 07:53 PM
Caddyshack
Caddyshack's Avatar
Side plug funny angle, is that supposed to be a blank?
Old 19-02-2018, 07:54 PM
mattman1234
yep,looks like its pushed out
Old 19-02-2018, 07:58 PM
Caddyshack
Caddyshack's Avatar
Is that a an over pressure type thing? Can't think why it would be there unless for assembly but then you would think it would have a retaining system?
Lucky save though eh?
Old 19-02-2018, 08:10 PM
Adam-M
Adam-M's Avatar
Caught just in time by looks of it, are you running 4x4 running gear? Just wondering as I see a sump gasket and didn’t think you fitted them in 4x4 format.
Old 19-02-2018, 10:47 PM
Mad_Mat
New Owner
Mad_Mat's Avatar
Wow that is lucky. I wouldn't expect that with a Cosworth pump either.
Was your oil pressure still good?
Old 20-02-2018, 07:22 AM
nixon_2wd
nixon_2wd's Avatar
Wow good thing you decided to go dry sump and caught it!
I believe thats the pressure spring retaining cap for the spray bar.
Old 20-02-2018, 04:55 PM
mattman1234
yeah,,was a lucky save,maybe they needed to use a harder punch
Old 23-02-2018, 07:19 PM
mattman1234
sump pan arrived today
Old 23-02-2018, 07:33 PM
mattman1234
Its a 2wd setup
Old 25-02-2018, 01:24 PM
mattman1234
Anyone have a 4x4 oil pickup pipe they want to move on
Old 25-02-2018, 07:12 PM
mattman1234
Made a flange today,will either tap this for a banjo,or weld a the pipe straight into it.
Just poked that pipe in to check it lines up with the hole
Old 22-03-2018, 09:08 PM
mattman1234
Old 22-03-2018, 09:38 PM
Adam-M
Adam-M's Avatar
At main cap #3 is that two pieces of pipe pushed together? I wouldn’t run it the way it is but would make a good template to get one fabricated.
Old 23-03-2018, 05:20 AM
mattman1234
no, its solid underneath,its not a join,its the origional 4x4 pipes ,the larger pipe is just sleeve over the top to make it rigid
Old 23-03-2018, 09:01 AM
nixon_2wd
nixon_2wd's Avatar
Looks cool. Good mod. How did you incorporate the pressure spring etc.? I would consider maybe doing an oil change on that engine of yours
Old 23-03-2018, 04:41 PM
mattman1234
the spring is external,using this(slightly over the top),adjustable check valve.
gonna givethe spray bar, bit of a file,some paint and will look factory
Old 23-03-2018, 04:45 PM
mattman1234
This is what is underneath,ive brazed over the existing pipes.
Part of the pickup pipe is a spine that runs down the back,the sleeve is where the spine finishes
Old 02-04-2018, 04:30 PM
mattman1234
Finally happy with it
Old 02-04-2018, 04:59 PM
Caddyshack
Caddyshack's Avatar
That crank might need a polish...lol
Old 27-04-2018, 07:08 AM
mattman1234
All belts sorted now,now starting tank install and pipework
Old 28-04-2018, 07:48 PM
mattman1234
Thinking of putting a std type filter before and after the pump,any thoughts ,will it affect pressure much,i'm thinking not.The one after is a deffo
The reason i want before is that i'm getting the tank welded with extra unions.Just a bit worried about any swarf,as is a solid tank.
Old 28-04-2018, 07:50 PM
mattman1234
