Sapphire Cosworth Wont Idle
Hello, I'm hoping someone can help,
I have a 1990 4x4 cosworth that wont idle after approx. 20 seconds, the most of the sensors around the engine have been changed. I don't know what work has been done to the car before I bought it and not sure what power it is but I have told it is around the 280bhp.
has anyone had a similar problem and fixed it? it has an L8 ecu
is it possible it could be a fuel pressure regulator or ecu related?
any info would be greatly appreciated
Could be loads of things even a small air leak. You haven't said if the idle raises or drops (or both). You may be lucky and it could be the ISCV, but tbh I'd take the car somewhere to get it checked over properly by a specialist if you can, a decent health check of all the sensors won't do it any harm, but chasing a problem like erratic idle could see you mess around adjusting and swapping things for ages and getting nowhere.
The above might sound a bit over kill for you, but I had a similar issue with my 4x4 for years like this, it was an intermittent fault that was only diagnosed when the correct diagnostic equipment was attached and the TPS was found to be slightly off, plus it had a small air leak in the inlet cover.
That is exactly what it would do with a faulty map sensor, so eliminate the iscv next as that is the next most likely cause. If its not that then as suggested take it to a Cosworth specialist as it could be lots of things which they will have the expertise to find.
if it has lambda sonda than try disconnecting it to see if the lambda is playing up..
if there is no lambda have you tried to play with small screw on ecu but it looks its missing more air through throttle body as suggested before...basic adjustment of idle with iscv disconnected...
