setting up TPS PF01
setting up TPS PF01
Ok...Fitting the sensor and i have found some very conflicting info on how the PF01 is setup....
Mine (with the new sensor reads 4.42V throttle closed ( idle ) which gradually smootly drops to 0.41V ( throttle fully open......
Some people say that it should read 0V ( or their abouts ) throttle closed at idle, and as soon as the throttle is touched ( slightly open ) should jump to the 4.42V..then gradually lower to 0.41V
Which one is correct research is 50/50
Sierrasideways
17-10-2015 10:25 PM
wheelwizardrefurbs
22-09-2015 05:45 PM
