Battery wiring - connecting block HELP?
Old 22-03-2015, 09:58 AM
BRAMMER
BRAMMER's Avatar
Default Battery wiring - connecting block HELP?
Basically the wiring on the + of the battery looks like an accident waiting to happen - is there any products out there that i can mount all the wires to a neat connecting block then one wire to the battery.
I'm not too hot on wiring so links and info massively appreciated
Old 22-03-2015, 10:47 AM
kosienutter
Last Time, Get Off PF FFS
kosienutter's Avatar
I did this a few years ago and it has been brilliant + I gained half a volt too. It is even tidier than these pics now. Hope this gives you an idea.
Old 22-03-2015, 11:27 AM
bigdel
bigdel's Avatar
i know what you mean. It's been on my list of things to do for years, but I never seem to get round to doing anything about it
Got flat terminal blocks on mine so need something to fit them
Old 22-03-2015, 12:10 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Chopped mine out and ran all the wires to a connector block I got from demon tweeks
Old 22-03-2015, 12:11 PM
tony66
tony66's Avatar
Default flat connector
the standard ford battery connectors should have a flat plate with a few outputs for the smaller wires do you not have that?
those gold terminals look more akin to fast and furious than ford 80s tbh lol
Old 22-03-2015, 02:05 PM
fatboy billy
fatboy billy's Avatar
I have the little plate on mine I think I've just had to redo all the connectors as they'd all gone a bit crusty
Old 22-03-2015, 05:46 PM
BRAMMER
BRAMMER's Avatar
Basically i was after a block with say 6 options to mount each wire then one main wire going to the battery, i've tried to look for something but can't see anything
Old 22-03-2015, 05:49 PM
ajamesc
ajamesc's Avatar
Same as mine then lol small black box 2 studs in it for all your lives via ring eyes. Mine has one lead to battery but mine is via a cut out switch as its left for periods not in use
Old 22-03-2015, 06:54 PM
cozzy jeff
cozzy jeff's Avatar
chris ill be using the connector from the mk 5/6 escort,connects to the battery and allows you to connect all your wires to.
Old 22-03-2015, 07:36 PM
costina
Live long and prosper!!
costina's Avatar
This could be just for you.
http://www.ebay.co.uk/itm/FORD-GALAX...item20f8488406
Use this for all you aux supplies. so you will have a main feed for this and one for starter coming off battery.
BUT you can get them from Ford brand new for the same price lol
Old 22-03-2015, 07:41 PM
costina
costina's Avatar
Cant understand why you would want to buy a second hand part for more money than a new one........
Old 22-03-2015, 09:56 PM
Received 1,044 Likes on 998 Posts
What are all the little wires on the battery for.
Old 22-03-2015, 11:36 PM
jon@work
jon@work's Avatar
mount one of these on the secondary bulkhead behind the battery,a little bit of rewiring, and job done
http://www.ebay.co.uk/itm/Auto-Marin...item29ff821d97
Old 23-03-2015, 09:04 PM
BRAMMER
BRAMMER's Avatar
So mount that and putt all the rings on then tighten - then has a main lead to battery? looks neat
Old 23-03-2015, 09:30 PM
mk2cossy
mk2cossy's Avatar
Closest pic I have at the mo! You can just see the single live lead to the battery.
I put a junction box on the bulkhead.
TPM961
15-01-2018 10:50 AM
S3an
26-09-2015 11:39 PM
jay030787
18-09-2015 04:38 PM
Flatlinedan
18-09-2015 12:41 PM
S3an
13
13-09-2015 10:01 AM
Quick Reply: Battery wiring - connecting block HELP?
