eletrical problems help please
Old Sep 3, 2014 | 09:39 PM
matthewpickup's Avatar
matthewpickup
Default eletrical problems help please
hi all ,
so I have changed the complete wiring loom on the p100 with a sierra cosworth one so it all fits the way it should and just to make the change over a bit easier , however I have got problems with it ,
I only have a right hand side side light , no head light or full beam
no side light , head light or full beam on the left side
I do have the indicator's working on both sides and the back lights
on the rear lights I have no stop/tail or fog
there doesn't seem to be any power to the connector at the front or the rear .
all fuses are ok , I have changed over relays and still no joy , all earths are on that I can see
the switches on the steering stock I am guessing are fine as they worked with no problems before
so anyone with any ideas would be great as its doing my head in
Thanks
Old Sep 3, 2014 | 09:47 PM
doga-ot's Avatar
doga-ot
If stalks,relays and fuses are ok and you have good earth i would say check the loom for damage
Old Sep 3, 2014 | 09:51 PM
matthewpickup
yea I was thinking that , I will try the stock switch first , there is a part that's been joined by someone on the passengers side but don't know if to cut it out and make a new join , not the easiest to get to now with the rad and coolers in place if need be I will strip it out again
Old Sep 3, 2014 | 10:05 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
sidelight can be wired in from the other working 1, but investigate the dodgy wire first
main lights could be relay prob
Old Sep 6, 2014 | 10:28 PM
matthewpickup
thanks for the help so far , will get into the head ache tomorrow
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
