What BHP saph 2wd cosworth
Old 20-08-2014, 02:31 PM
robbo9006
robbo9006's Avatar
Default What BHP saph 2wd cosworth
OK ,i'm having to wait for my car.
What BHP will i get.
Here are the ingredients.
GT35 T4-8 T4 comp .70 A/R Turbine .96 A/R water&oil 500-600hp turbo turbocharger
Black siemen 83lb
bd14 inlet cam.
3 bar map sensor
msd chip
bosh 044 fuel pump.
uprated fuel regulater
rs500 intercooler
it will be live mapped eventually.
its got forged rod pistons cp and arp bolted through out.
External wastegate
Old 20-08-2014, 05:51 PM
jamie's
jamie's's Avatar
Standard head?
Old 20-08-2014, 06:47 PM
ginner
ginner's Avatar
Hope your long studding ya block
Old 20-08-2014, 06:49 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
If your asking that question can i suggest a rather loud BANG!!
Old 20-08-2014, 07:10 PM
Cos500
Cos500's Avatar
I would suggest a live map straight away and hope you have brakes, suspension and tyres to match the performance
Old 20-08-2014, 07:12 PM
costina
Live long and prosper!!
costina's Avatar
You can only long stud a 200 block and I would advise not to use arp studs on any 205 or 200 block as they crack them.
As for a figure not a clue
Old 21-08-2014, 09:21 AM
robbo9006
robbo9006's Avatar
TR1 proxies.
18" dynamics
Koni suspension and
not decided on the brakes as i have some Brembo's on another car and there not as good as the standard cosworth ones.
It's not studded but i didn't aim for the 83lb injectors and was going to go with greys.
Hopefully i can smooth the power out on the live map.
It is going live map and close loop.
Its not a track car and is only being used on sat morn drives.
Old 21-08-2014, 09:42 AM
cossynut2
cossynut2's Avatar
Originally Posted by robbo9006
TR1 proxies.
18" dynamics
Koni suspension and
One word of advice I can give is without a doubt get a big brake conversion as the standard Cosworth brakes will not be up to the job of slowing down a potentially 450+ bhp car.
Old 21-08-2014, 10:26 AM
robbo9006
robbo9006's Avatar
Yes .
I will.
Thankyou.
Ive just to get her running and then ,i have all this to sort.
I am holding out on the brake decision, as the Brembo's i have won't be good enougth.
once shes running and sprayed.
Old 21-08-2014, 10:29 AM
DAN400
DAN400's Avatar
is the head going to be std ?
Old 21-08-2014, 10:43 AM
robbo9006
robbo9006's Avatar
yes.
its a 4x4 with a skim on it.
Iv'e put cp low compression pistons in.
Old 21-08-2014, 10:53 AM
DAN400
DAN400's Avatar
big turbo and std head wont work to well imo
Old 21-08-2014, 11:00 AM
robbo9006
robbo9006's Avatar
http://www.ebay.co.uk/itm/2804660805...%3AMEBIDX%3AIT
I only wanted grays.
Well i will have a look at this.
Thing is if i keep uprating something will give.
I will put this head on if i get the engine running of the chip.
Re do the sills and get her pretty again in the spray shop.
I would have to put the head on before the live mapp.
I will have to order a outlet cam.
i have a bd14 inlet ,i wouldn't change that.
i would just put a outlet cam in.
Old 21-08-2014, 11:03 AM
DAN400
DAN400's Avatar
id get the head ported , ditch the 14 inlet for a 16, and leave the exhaust cam std
Old 21-08-2014, 11:07 AM
robbo9006
robbo9006's Avatar
Fair enough.
Thanks
Old 21-08-2014, 12:05 PM
ginner
ginner's Avatar
Think you need to speak to a tuner mate as that turbo will rip the head clean off if you don't long stud it and I'm supposing your using a 200 block
Old 21-08-2014, 12:27 PM
robbo9006
robbo9006's Avatar
i may need a smaller turbo.
I may do this and go back to the grays.
Thankyou
Old 21-08-2014, 12:29 PM
Staffi
Staffi's Avatar
I wouldn't bother with Greys, much better injectors on the market, how about a 3071 or a T36 ??
Old 21-08-2014, 12:40 PM
jontysafe
jontysafe's Avatar
Turbo not really suited to the job. I`d go 3071 on this spec. Double valve springs with BD14 inlet and standard exh cam. 4x4 or small turbo escos inlet manifold. Decent breather set up and air inj boost control with live map.
Old 21-08-2014, 07:11 PM
Cos500
Cos500's Avatar
Sounds good to me
Old 12-09-2014, 04:58 PM
robbo9006
robbo9006's Avatar
Well my mechanic couldn't get her started.
I took her to James at MSD and he worked his magic and found a well dodgy wire going to the amp.
The car is running.
Some good sound advice on certain quality loom issues.
I am pleased.
I am having the lamba sensor fitted and some service items ,
I will take her away and get her sills done and MOT.
I have all the parts now for the exterior .
These will be fitted and a respray next.
Back to MSD for some Gucci items then drive her sensible and get some time with her a live mapping after a wee bit of time..
Old 28-11-2014, 05:04 PM
robbo9006
robbo9006's Avatar
I have just received the car from MSD.
She had a new engine loom ,fuel pump loom,air injectors fitted.
She runs well but needs a live map to get her opened up,
I have to change oil and take her for a mot and have sills welded.
The sill work is booked in for next Friday.
These cars are a good life time project.
It's like having a dog.
There not just for driving there a life time commitment.
09-10-2015 07:38 PM
155lee
14-08-2015 11:21 AM
14-08-2015 07:29 AM
ray barker
07-08-2015 09:00 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: What BHP saph 2wd cosworth
