Secs monitor
Old 25-07-2014, 09:39 PM
saphcoz31
Saphcoz31
saphcoz31's Avatar
Default Secs monitor
Hi all, Just wondered what is more accurate for reading my boost level as my secs monitor reads about 3psi less than my boost gauge, I'm peaking at 29psi on secs but 32psi on gauge just be nice to no as with the hot weather I would rather it be 29psi.
Old 26-07-2014, 08:26 AM
nicksaph
nicksaph's Avatar
i would have said the secs monitor is more accurate as it is rearding what the ecu sees.
analogue gauges can be notoriously inaccurate.
cheers nick.
Old 27-07-2014, 09:38 PM
kosienutter
Last Time, Get Off PF FFS
kosienutter's Avatar
My secs on idle says -12 and boost gauge says -25 but both above 0 read roughly the same. Secs is more accurate.
Old 28-07-2014, 08:43 AM
James @ M Developments.
James @ M Developments.'s Avatar
29psi is more than likely the max reference of the 3 bar map sensor, if you ran 60psi of boost the secs would still show 29.
Old 28-07-2014, 07:34 PM
saphcoz31
Saphcoz31
saphcoz31's Avatar
Thanks for your replies guys as James says I think it is the max it can read from the map sensor, Cheers for your help.
pabloXR
21-09-2015 12:42 PM
Roscopeco
14-09-2015 05:32 PM
Bailes1992
03-09-2015 02:17 PM
K42L
28-08-2015 01:23 PM
Bailes1992
16-08-2015 07:14 PM
Quick Reply: Secs monitor
