Hi all- does anyone know the standard castor of a 3 door?
Thanks for your help.
Tim.
It should be around 2.5 degrees with the early ARB ( H13 type ).
If it's had the later H14 type ( offered as a recall/or on late builds and also found on RS500 and 2wd Sapphire ) it should be around 3.5 degrees. The ARB type is marked on the bar end if you look hard. With the H14 the wheel will sit quite close to the front of the arch and might even foul the front bumper on heavy lock.
