Aftermarket front ABS sensor
Old 24-11-2013, 06:25 PM
Cauf61
Cauf61's Avatar
Default Aftermarket front ABS sensor
I was chearching for a aftermarket front ABS sensor and found this one.
Mapco 86102.
Maybe this could work , I only need to change the connector , whats not a problem.
I have sended an email at Mapco for the mechanical details. Let's hope they fit .
Or maybe somebody works at a shop where they have these sensors and can take mesurements.
I think electrical al sensors are about the same ( +-1100 ohm resistance )
Wil be continued.
Old 02-12-2013, 04:46 PM
carl/saff
SIERRA RS 4X4 COSWORTH
carl/saff's Avatar
Any updates ..... gen ones are 150 quid off ford.lol
Old 02-12-2013, 05:58 PM
Cauf61
Cauf61's Avatar
Yes
Had an answer from Mapco.The size should be the same !
I have orderd one.
Let's hope it works.
Old 02-12-2013, 06:22 PM
jon@work
jon@work's Avatar
let us know how you get on
Old 08-12-2013, 05:58 PM
Cauf61
Cauf61's Avatar
Hi good news and bad news.
It can be fitted whitout a problem.
The size is exactly the same.
I have tested it and a ford sensor gives about 40- 60mV when turning hard on the wheel but sadly the mapco one only 3-4 mV which is way to low.
Very strange because the internal sensor resistance is for both +- 1100 ohms.
The only difference is that the ford has 2 visible little iron cores at the open front and the mapco type is closed at the front.
What i have also found out is that the modern wheel rings have bigger teeth then the old fords.
Here the teeths on the inner ring are very small.
I will look futher in to it
original
30-01-2022 08:20 PM
manuel boeckx
13
03-10-2015 02:29 PM
costina
18
25-08-2015 06:02 PM
C2 MAK
20-08-2015 09:46 PM
rdvil
Other Marques
15-08-2015 12:11 PM
Quick Reply: Aftermarket front ABS sensor
