Staph Cos brake problem
I've got a 4x4 sapphire cosworth and have lost most brakes?
Pedal is still there but is pretty solid. I was thinking its the servo but was wondering if there was any common faults with these thinks?
Cheers,auld
Cheers,auld
The red light usually comes on when there's a drop in pressure in the system, fluid loss or another fault with the system. Did the amber warning light come on at the same time? If the fuse checks out ok, you need to start looking at whether the pump is working ok (you should hear it pressurise after being left overnight), fluid level in the M/C. Another good one on these systems is the accumulator looses pressure. This is basically what gives you your 'servo effect' a normal braking system has. If that goes, you'll need a new one. I wouldn't drive it until you got it fixed though, as it's bloody dangerous
Thanks again guys.
Checked out the fuses in the n/s under the dash and they are all fine.
I'll need to check the other suggestions that marcyg has mentioned.
Cheers,auld
Cheers,auld
A 4x4 should have 2 relays and 2 fuses to operate the pump at 140 bar system pressure and then 105 bar if the first circuit has failed. As the pump isn't working, then both circuits have failed.
The common features of these 2 circuits are:
- the wire from the pressure switch to earth (brown)
- the connector on the pump
- the battery positive feed
Test:
- Check you've got 12V at terminal 30 of the 2 purple relays. If not, check the fuses and also the fusible link by the battery
- Check the connector is located correctly on the pump
- Check the brown wire in the pressure switch connector is indeed connected to earth
Of course, it is possible you have 2 separate faults........Test, then let us know.
Test:
