Help needed after rebuild
Hi every1 I haven't been on here for a while as been rebuilding my saph had 4 new sleeves new crank bearing seals ect ect the problem I'm having is the car runs perfect and engine is silent but when engine warms up its gets a rattle that's is similar to rod knock but no we're near as bad and it looks like oil is getting very thin when warm but if I let it cool down and start from cold it's perfectly silent again iv always used same oil without problems before 10/40 but Is this to thin for a freshly rebuild yb?
i suggest you do one mate. when i rebuilt my rst crank regrind etc etc i had the same problem! i changed everything! and then finally found out that the main bearings were the wrong size block side! im not saying this is your problem but you need to know if its actually dropping pressure or not. if not then you know to look down other paths.
get an adaptor then. or just borrow an oil pressure tester kit if you can. but if it is low oil pressure then it will be causing damage when it drops. from what your saying tho i would say its the wrong bearings fitted.
steerfromdarear
28
29-01-2016 06:14 PM
matman
09-09-2015 05:45 PM
track.focus'd
12-08-2015 05:53 PM
