Fitting 2wd exhaust manifold onto 4wd?
I have a sierra cosworth 4x4 that has been converted to 2wd.
It still has the 4wd exhaust manifold fitted so i plan to fit a 2wd item.
Is this a simple swap over??
What else is needed???
I know turbo may need to be spun
hmmmmm looks like ill leave it alone then!
if u do a search on here all u see if bad things about 4x4 manifolds being restrictive to big bhp
more torque
less power
more torque
less power
Unsure tbh untill i check it all, atm unknown t38 greens chip 3 bar etc
But will go seimens & new chip when turbos rebuilt.
Gonna get a few prices on rebuild this week
Do you do them?
Do you do them?
I was thinking of doing the same, am I being misled? I`m running the following spec:
SIERRA COSWORTH 200 block with ported and polished KarlNorris head. Wiseco pocketed race pistons and rings. BD16 inlet cam and BD14exhaust cam. Double valve springs. 6 Long Stud block conversion. Internallygated GT3076r. 4x4 exhaust manifold. Stainless steel turbo down pipe. 2wdmodified inlet manifold matched to head. Siemens 83lbs injectors. 7.9:1 C/R. Currently only running 1.3 Bar as on first 1000 miles since rebuild.
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
track.focus'd
12-08-2015 05:53 PM
