3 Door Aero
Spoilers are designed to work at high speed, the only reason ford added it was because the car was capable of 150+mph so needed something to keep the arse down on the sierra at such high speed.
if you were going round a track, and taking a bend at 90mph your car will stick tarmac as it should. if you didn't have the spoiler the car would over steer considerably.
You can't just say that a 3dr WILL stick through corners at 'XX' speed, it depends what traction is available, turning forces are involved etc etc
The 3dr may well produce downforce at 90MPH with the tail on but it will only just be -ve lift, you'll have to find out what KG of downward pressure is added at what speeds and find out how much extra traction you gain from that depending on your tyre grip/speed/testicle size when you try to go faster for the first time.
Try a set corner that you can manage 90+ with no tail on and note the maximum speed you could get through it before the car slides at the rear, then repeat it with the tail on- you should feel it more planted at the rear/have more front push at the same speed that you noted earlier. Then have a go at finding the limit of grip WITH the rear tail.
because the above posts seem to point towards a bit of downforce as being a 'grip switch' or something lol
Resident Wrestling Legend
the 3 doors didn't have the larger rubber flaps on the rear windows that the later sierras got to aid with cross wind stability
let me find some pics to show you what i mean and you will understand the sierra aera a bit better in the case of the 3 door vs the 5 door
the pieces on the rear windows of that mk2 were a revised item and a call back for mk1's as it was due to swaying/stability problem with the mk1's at a certain speed, also id imagine the weight of cosworth bumpers and spoilers arches etc is enough to keep it down as if you compare them to standard mk1 sierra items they feel as though they weigh more then twice as much
RS500 rear wings produced 100kg downforce at 100mph.
On the 3-door Cosworth the rear wing produced about 20kg downforce at 70mph. If Lothar Pinske, Motorsport boss, had had his way it would have been more but the designs were 'softened' somewhat for the road, especially at the front .
Having said that, the normal road cars would produce quite a lot of 'lift' at those speeds, so those figures for the RS cars have to be taken in context. There was an interesting article in "Motor" mag years back when John Miles, who did some aero work on a 3-door XR4i shell in readiness for the RS cars' aerodynamic addenda examined the differences in lift, yaw and Cd in the wind tunnel.
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
Vacuman
22-09-2015 12:09 PM
