Saph Boa turbo conversion!!
26-04-2013, 11:00 AM
so your pretty much done then, you got anything else that needs doing over the weekend ?
26-04-2013, 11:26 AM
Resident Wrestling Legend
don't forget to remove the metal band on the doughtnut when you fit it
26-04-2013, 11:33 AM
Quote:
Originally Posted by
asha1
yeah need to run fuel lines and tighten some bolts on rear shafts
but i'm really stuck with loom.
26-04-2013, 11:34 AM
dojj
Did that already bud any luck on the front shocks?
26-04-2013, 12:01 PM
i'm headed over there this afternoon mate, as soon as i find/don't find them i'll let you know
26-04-2013, 12:05 PM
give us a bell tommorow if you need me at all mate, can't wait to see it running !
26-04-2013, 02:36 PM
27-04-2013, 07:16 PM
Fitted rear brake lines today just the front to do now shouldn't take long!
27-04-2013, 07:48 PM
Fixing Fords
Looking good mate send us an address and I will send those bump stops you need
27-04-2013, 08:06 PM
Fart of the Purniture
It's coming on now Wes, we just need to find you a wiring guru!
Did you get the prop sorted?
27-04-2013, 08:10 PM
27-04-2013, 08:12 PM
mk22door
sort of lol I have also sorted front shocks, so its just a case of fuel lines and wiring 1 stub axel and exhaust
27-04-2013, 08:28 PM
Fixing Fords
I will bring that other boa loom I found over too mate
27-04-2013, 08:36 PM
Ok cheers bud then I can try strip mine down using that as a guide
Fixing Fords
You have a diagram you can send me ?
27-04-2013, 08:51 PM
Yeah I have about 5 different 1's in a folder and some in an email from capriV8driver, I'll email you it
27-04-2013, 08:55 PM
Fixing Fords
27-04-2013, 08:56 PM
Does this help?
27-04-2013, 08:58 PM
Probably not the quality is a bit shit to say the least
27-04-2013, 09:22 PM
Fixing Fords
Should be fine
To this
In mine running stand alone.
27-04-2013, 09:34 PM
Yeah lol that is spaghetti to me.. I'm mechanical minded and can usually work out how to do something but wiring not a hope best i can do is wire a plug or switch thats about it
27-04-2013, 09:38 PM
ELASTIC BAND
Ah the brake lines make sense now!
27-04-2013, 09:42 PM
Lol now you can do yours!
27-04-2013, 10:02 PM
ELASTIC BAND
27-04-2013, 10:13 PM
Tim to replace your sig hey bud lol get pic of the saph will look good
30-04-2013, 08:19 PM
Right front 4x4 koni's now sold and my front 2wd koni's and rear stub axle ordered from Gary@rsclassics, ABS loom should be with me by end of next week brake lines all connected now so by the end of the weekend car will be on all 4x wheels and ready to go minus the loom and exhaust. As soon as ABS loom arrives I will fit and bleed brakes.
30-04-2013, 08:26 PM
So the gearbox piece arrived and fitted ?
30-04-2013, 08:57 PM
Yeah all bolted up cheers bud! graham has that bit just got to get over to him with my old engine arms for a swap!
30-04-2013, 09:51 PM
Cool
Send it when you get sorted mate.
05-05-2013, 07:17 PM
Abs loom arrived Friday thanks to "David" will get it fitted Monday. I'm a bit pissed off as car is basically finished now, all that's left to do is put front shocks/springs/hubs brakes etc on and drivers rear stub axle (ordered from Gary@Rsclassics Monday) still not here hopefully Tuesday. then its just fitting 24v loom and sorting exhaust I really cant wait at least it will be ready for classic ford!
06-05-2013, 08:18 PM
You'll get there mate
There's a bloke called mick (name appears in red) on the Sierra forum got a cheap exhaust for you. look in for sale section.
06-05-2013, 08:28 PM
07-05-2013, 07:21 AM
mk22door
he's on here as well
14-05-2013, 08:13 PM
Right UPDATE time:
Car is about 97% complete now wiring is done and fitted/plugged in the engine bay now thanks to Ade500 cheers bud
just a hand full of wires to soldier up tomorrow.
I have now run and connected all new copper brake lines, I now have an exhaust thanks to Mick will fit it tomorrow.
Stub axle and front koni's arrived from Gary@rsclassics and have all been fitted. will put up some more pics in a minute, all that is left to do now is;
steering coupling
engine oil
gearbox oil
diff oil
brake pads
rear drive shaft bolts need torqueing up
and need to remove and sort prop out
14-05-2013, 08:18 PM
14-05-2013, 08:19 PM
Old loom out
14-05-2013, 08:20 PM
New loom in
14-05-2013, 08:21 PM
Brakes piped
14-05-2013, 08:29 PM
Nice one Wes
And nice one to Ade for helping you out
V6's sound awesome mate
14-05-2013, 08:44 PM
I haven't forgotten about you bud or that bracket I owe you!
Hoping after work tomorrow to get prop off and cleaned, and soldier the wires in the dash. But I also got too go help ma pa as I have a Capri 2.8i special to pick up for him (another barn find)
