Saph Boa turbo conversion!!
Old 14-07-2014, 08:17 AM
  #441
Marc sierra
Marc sierra's Avatar
So the length isn't the problem?
Old 14-07-2014, 10:46 AM
  #442
doga-ot
doga-ot's Avatar
The prop is the correct one length wise (twincam prop) as i bought another which i took of my mates 3dr boa and it is exactly same as my one
Old 15-07-2014, 05:21 PM
  #443
doga-ot
doga-ot's Avatar
May have figured out my prop problem we will see tomorrow if what I have planned works.
Today after work I removed old plugs replaced with new and charged battery over night car still wouldn't start have spark but no fuel "fuel pump has died so ordered 1 from Gary @rsClassics tempery as I will get a new uprated one but this will do for time being so I can run car.
Old 17-07-2014, 01:06 PM
  #444
doga-ot
doga-ot's Avatar
Fuel pump arrived today will fit tomorrow as should be home early as today I have kids sports day and present buying for my eldest boys birthday! Pulled engine forward yesterday have not offered prop up though to see if it has made a difference if any or i'll have to order an escos donut!
Old 17-07-2014, 04:08 PM
  #445
Received 1,044 Likes on 998 Posts
I hope it starts matey.Were you getting a spark at the spark plugs.
Old 18-07-2014, 06:57 AM
  #446
doga-ot
doga-ot's Avatar
Not tested spark plugs for spark but coil pack and leads had power used a tester! Will try get pump fitted today but so busy if not it will be done tomorrow as i have Simon coming back to wire fans gauges and a few other bits!
Old 18-07-2014, 10:09 PM
  #447
Any look today????
Old 18-07-2014, 11:23 PM
  #448
doga-ot
doga-ot's Avatar
Originally Posted by Glenn_
Any look today????
As said didnt get a chance with it being my boys birthday, tomorrow (today saturday) i doing a mates waterpump on his bmw at 7am then i'll do fuel pump and Sinon is coming in afternoon hopefully we get her started!
Old 18-07-2014, 11:25 PM
  #449
doga-ot
doga-ot's Avatar
Rich (mk22dr) i bought a rwd mt75 gearbox got to pick it up in next few weeks from my mate when i do i'll send u that bit u gave me as it has everything on it
Old 20-07-2014, 09:41 AM
  #450
mk22door
Fart of the Purniture
mk22door's Avatar
Cheers fella
Hope you get her going mate, seems to be testing you this SIerra.
Old 21-07-2014, 11:38 AM
  #451
doga-ot
doga-ot's Avatar
Originally Posted by mk22door
Cheers fella
Ahhhhh dnt mate! Simon never came as he was ill came down with the bug thats going around, couldnt change fuel pump more to it so new tank ordered should be here tomo what a pain in arse my tanks full of fuel! Dropped tank standard 2000e with uprated internal fuel pump which is dead but i ordered a cossie pump as thats what i thought was already on car nightmare if i had hair id be pulling it out... Just want her done now im so so close
Old 22-07-2014, 06:35 PM
  #452
mk22door
mk22door's Avatar
Patience is obviously one of your many qualities mate.
You'll be done soon and be enjoying it (that's what I keep telling myself)
Old 22-07-2014, 09:18 PM
  #453
doga-ot
doga-ot's Avatar
Old 27-07-2014, 07:03 PM
  #454
doga-ot
doga-ot's Avatar
Right good news, well over due. After fuckups like illness/rain/parts not turning up etc Simon came this morning wired fans, gauges and fuel pump etc he even managed to get my pump running however pump is shagged it doesn't make anywhere near enough pressure for her to fire over as BOA need min of 3bar sprayed easy start bang she fired up and ran for min or 2. So now saph cossie tank, pump cradle arrived minus sender unit which Gary will send out in morn as he forgot as soon as it arrives will fit it all but need to source another cradle as one I got is very bad not saveable!
Old 27-07-2014, 07:08 PM
  #455
Top news matey.I bet you relived now.
Old 27-07-2014, 07:10 PM
  #456
Ade500
Fixing Fords
Ade500's Avatar
Almost there mate
Old 30-07-2014, 10:09 PM
  #457
doga-ot
doga-ot's Avatar
So stripped cradle down yesterday and cleaned shot blasted it now looks better but very thin got to primer it before fitting, but just spent Ł150 to get tank, pump and cradle etc only for my ciusin to tell me to day i got spare tank cradle pump and bits etc i can have ����������
Old 30-07-2014, 10:26 PM
  #458
dojj
Resident Wrestling Legend
dojj's Avatar
you used to be able to get remanufactured hangers from somewhere a while ago, i'm sure someone will let you know where from
Old 31-07-2014, 12:23 PM
  #459
mk22door
mk22door's Avatar
Nearly there mate
Old 06-08-2014, 07:43 PM
  #460
doga-ot
doga-ot's Avatar
Right here goes wanna cry lol stripped tank down and cleaned up with wire disc on grinder all was fine then I came to do around the flow and return pipe so 1st up I had to remove the hoses that came attached. Undid jubilee clip on return and thewhole thing fell off, flow just came straight off to then fine a big hole and a small hole in the base of the connection, so msged Gary @ rsclassics he is gonna send another tank but I am umming and arring about buying a new 1!
put a right downer on things as I had ordered 2m of braided an-6 ptfe fuel hose and the banjo fittings to make the 2 pipes I need (pump to accumulator and accumulator to filter) also ordered the cradle anti vibration rubbers and got a black saph rs steering off of Fil (will add pics of all the above and more in bit or tomorrow) also stripped down and cleaned cradle then acid etch primer and then primer will paint Friday and if tank comes by weekend car will be running!
Old 06-08-2014, 08:19 PM
  #461
mk22door
mk22door's Avatar
Fuggin' hell mate!!!!
it's got to be pissing you right off now
Old 06-08-2014, 08:39 PM
  #462
doga-ot
doga-ot's Avatar
yep not far off I plan on going Holland in Sept for the European Ford Event and looked like I'd be going in Saph but not now
Because she needs to go in my cousins to have new wing and 2 inner sills fitted and need to take her on a good run 1st too (to me nans in Norfolk 3hr) 6hr all in as I don't really fancy going on a 5hr30min drive too Holland in another country and something happening.....
Old 06-08-2014, 08:53 PM
  #463
dojj
dojj's Avatar
these things are snt to try us mate, but at least you'll know every single nut, bolt and fitting on your car eh
Old 06-08-2014, 09:02 PM
  #464
doga-ot
doga-ot's Avatar
Old 07-08-2014, 11:48 AM
  #465
doga-ot
doga-ot's Avatar
Old 07-08-2014, 11:50 AM
  #466
doga-ot
doga-ot's Avatar
Old 07-08-2014, 11:53 AM
  #467
doga-ot
doga-ot's Avatar
Just waiting on tank from Gary and got to spray paint the cradle yellow or red!
Old 07-08-2014, 11:59 AM
  #468
dojj
dojj's Avatar
seeing as you can't really weld a fuel tank a replacement is the only way to go from where i'm sitting mate
Old 07-08-2014, 01:03 PM
  #469
doga-ot
doga-ot's Avatar
Gary sending me a replacement bud all i did was remove the off cute of pipe it came with and found the hole on flow and the return just fell apart! Was gonna buy a new 1 may still do that in month or 2. But for now the replacement should be on its way and will be good enough to get the old girl back on the road for now
Old 07-08-2014, 01:08 PM
  #470
Fil
ELASTIC BAND
Fil's Avatar
That's a bit shit, always something cropping up, still lucky you cleaned it up before fitting, as might have lost a bit of fuel!
Old 07-08-2014, 01:16 PM
  #471
doga-ot
doga-ot's Avatar
Thats the point though Fil look at the pics i hadnt cleaned that bit i was removing off cuts of hose from flow and return to then clean it but never got that far as it was fucked i had already cleaned the rest of tank though!
Old 07-08-2014, 01:50 PM
  #472
Fil
ELASTIC BAND
Fil's Avatar
Yeah alot of hard work for nothing.
How much are brand new tanks?
Old 07-08-2014, 04:20 PM
  #473
doga-ot
doga-ot's Avatar
Ł84 bud
Old 08-08-2014, 11:03 AM
  #474
doga-ot
doga-ot's Avatar
Old 09-08-2014, 11:40 PM
  #475
doga-ot
doga-ot's Avatar
All put together and awaiting fuel tank and some aeroquip jubilee clips
Old 10-08-2014, 08:21 PM
  #476
doga-ot
doga-ot's Avatar
Just ordered New fuel tank be here Tue-Wed!
Old 10-08-2014, 08:26 PM
  #477
mk22door
mk22door's Avatar
Looking good fella.
Its got to be going sooner or later
Old 10-08-2014, 08:36 PM
  #478
doga-ot
doga-ot's Avatar
Looking good fella.
Yeah wee bit pissed off to be fair as wanted her for Holland!! Plus haven't heard back from Gary whether he sent another tank out and I need her running then once run in I can sort my niggles out like fitting proper aeroquip fitting instead of jubilee's, removing plenum and rocker covers to spray them change my grey dash for black and few other bits plus she got to have driver wing inner rear sills and respray!
Old 13-08-2014, 08:14 PM
  #479
doga-ot
doga-ot's Avatar
This arrived today very happy as long as weather is grand tomorrow gonna get it and pump fitted piped up, then see if she fires up!
Old 13-08-2014, 08:17 PM
  #480
doga-ot
doga-ot's Avatar
Just need to buy 1 of these tomorrow.
Quick Reply: Saph Boa turbo conversion!!
