Jamie that looks awesome, bet you can't wait to get the engine in now! Look forward to setting that one up
Yer couple more little jobs to figure out then just need to tackel the wireing then will be ready to run, will be brining it back once up and running for a check up, should be abit easyier than them rally car for you and your dad to get in as its built round me
Bet it's lively??any issues with running that boost??mite turn mine up
It's not to bad mate..abuse it and all hell breaks out... Well I had the turbo built to has best it could be with a Maram shaft and other stuff etc... It's lasted 1400 miles so far and it's had a hard life and its still fine... But how long it will last no one will ever know.
I've got a 2wd with an l6 ecu 044fuel pump gray injectors 4wd inlet 3bar map sensor 50mm front mount t38/48 roller turbo 200 block an head I've got the l8 ecu will that just plug into my 2wd saph or not an wot bhp should I get with a map
The boys above got 385 bhp on that setup, your l8 won't quite be plug and play you need to change the pins for throttle pot and run a pf09 throttle pot
There hens teeth to get hold of tho I fink there's a bike that has the same pf09 Ducati if I remember a thred on here not to long ago who can swap that the mapping place
Whoever you chose to map it would fit and set it up for you
Wow that's a good way to go from croxley I would have to trailer mine up there cos I wouldn't want to drive it that far
i trailered mine up there 2 weeks ago and trailere it back on thursday ...takes about 2.5 hours each way from croxley but all the work they have done for me has been outstanding
I've just heard bout a place in uxbridge that's got rolling road mapping an live maps so gona pop down there this week up near hairfiled mapped a mates RS focus might see wot there saying about mine for a giggle
