Loom removal advise needed
Im currently removing the loom from my 2wd saph shell im at the point where i need to pull through bulkhead where fuse box sits.is there any particular way of doing this? How do you remove fuse box? Or is there another easier way of going about all this?
Thanks in advance.
Thanks in advance.
Pick-up P100 Power!
I've just taken the loom you of my p100, piece of piss! Now I'm trying to put a 4x4 cossie loom back in! Fuck me its 20 times the size of the one I took out!
Take the engine loom out 1st and the push the engine bay loom though in the foot well and back out of the fuse box hole. The fuse box is held down with 4 x 8mm nuts on the underside of the bulkhead. Then just pull a bit through at a time. Its a ball ache!
kosienutter
31
22-08-2015 09:55 AM
muz
16-08-2015 12:57 PM
