cosworth pas onto base model will it fit?
does anyone know if a saph 2wd cosworth power steering rack fit fine into the standard base model 3 door front crossmember? and if the lower steering column joint will also fit or is it a different size?
cheers nick
cheers nick
Already got the pump fitted it's all fitted with the belt system from an escort with 1 bracket just unsure if the rack will fit mainly at the steering column rack joint
Would have thought you would need a cosworth steering universal joint as well, as I know these are different to other models, presume the column is the same though, think from memory it is triangular in section where it comes through bulkhead
well this is the part im worrying about whether itll need changing or not
http://www.ebay.co.uk/itm/FORD-SIERR...07764596674406
not sure of its correct part name but i heard before that a 3 door cosworth one is different to a saph 2wd cosworth one and so therefor does that mean a 3 door cosworth and 3 door base model sierra have the same one or will they be different?
anyone ever fitted cosworth power steering to a base model 3 door before?
steerfromdarear
28
29-01-2016 06:14 PM
155lee
14-08-2015 11:21 AM
