4 pot calipers
Old 16-01-2012, 10:18 PM
p100rallyesport
p100rallyesport's Avatar
Default 4 pot calipers
Hello all just a quick one is there any difference between 2wd and 4wd 4 pot callipers????
If so what is the difference???
Thanks in advance
Old 17-01-2012, 12:00 AM
CosworthGuy
3dr Cosworth owner
CosworthGuy's Avatar
I assume your talking about the fronts? I didnt think the 4wd came with 4pots. Just 2 pots. may be wrong but even if they are 4 pots they are different
Old 17-01-2012, 12:38 AM
Micky
Micky's Avatar
4wd saffs came with a 1 pot sliding caliper,it was 2wd saffs that were fitted with 4 pots.A 2 pot was never fitted to any RS Ford!!!
Old 17-01-2012, 10:38 AM
Eigdoog
±§~Quadzackular~§±
Eigdoog's Avatar
Surly the 4wd would of been better with 4 pot brakes?
Old 17-01-2012, 11:38 AM
blue oval 24v
blue oval 24v's Avatar
yea it was the 2wd came with the 4pots and the 4wd came with 1pot with sliders
Old 17-01-2012, 12:18 PM
martysmartie
martysmartie's Avatar
Yes but 4WD were not 2WD running gear, so oviously money isn't going to be spent if they can otherwise cut back.
As said 4x4 doesn't have 4 pots, it's simple single pot sliding design all round, front discs are different sizes at the front as well, and are a different type at the rear.
Martin
Old 17-01-2012, 12:30 PM
p100rallyesport
Ok so the difference is 2wd had 4 pots and the 4x4 didn't!!!
Got it lol
So I assume the discs to suit the 2wd 4 pots are tge 283mm????
Old 17-01-2012, 09:28 PM
Eigdoog
±§~Quadzackular~§±
Eigdoog's Avatar
Martin
Could you put 2wd calipers on a 4wd? I bet i have to make a stupid bracket that i could never make lol.
I understand would the money cut backs and all but 4 pot is going to be better so really ford should of put them on and just charged customers.
Old 17-01-2012, 09:46 PM
Rsmat
300+
Rsmat's Avatar
Mount a lot different... Sure 4x4 the calliper is at the front and 2wd there at the rear of the disk...any reason for this...?
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
155lee
24-10-2015 11:11 AM
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: 4 pot calipers
