Heater Matrix on a sapph?
Old 15-01-2012, 09:35 AM
Bloomers
Cornish Fasty
Bloomers's Avatar
Default Heater Matrix on a sapph?
What sort of job is it? i keep getting a wafting smell of coolant inside, so i'm suspecting 5 months parked up has called time on my matrix.
usual dash out job? or can i pop off the lower piece and pull it out?
Old 15-01-2012, 11:33 AM
LHD220Turbo
LHD220Turbo's Avatar
i did mine; but i cant exactly remember what i took out; i'm pretty sure i only took the lower section of the dash out and removed the matrix from the drivers side
i did mine about 4 years ago so cant remember exactly how i did it, but deffo not whole dash out
Old 15-01-2012, 06:08 PM
tosh
tosh's Avatar
Yes you just need to take the lower dash out mate, it's also a good time to refurbe all the seals on the heater box bafels which makes a world of difference in the summer by stoping warm air getting into the cab from the matrix.
Old 15-01-2012, 11:05 PM
langer
langer's Avatar
as above its not to bad to do just the lower section off and bobs ya uncle
Old 16-01-2012, 07:55 PM
cossiestu
cossiestu's Avatar
I did mine, when I built the engine, (snapped a pipe off) dont remember taking much of the dash out, only the lower part, if the lower part is split, I might of just taken one side out....? Was about 6years ago. Don't remember it being that bad a job?! Good luck with it!
Chas
05-10-2015 07:13 PM
DavidK
27-09-2015 02:55 PM
Flatlinedan
18-09-2015 12:41 PM
Quick Reply: Heater Matrix on a sapph?
