Ford Sierra 2.0i pinto ECU difference (N4B and N4A)
Old 08-11-2011, 09:36 AM
Martinss
Martinss's Avatar
Default Ford Sierra 2.0i pinto ECU difference (N4B and N4A)
Hello!
I have ford sierra with 2.0i CAT pinto engine (N4B I suppose?), problem is with lambda sensor it is dying or already dead. Also CAT is cutted out a long time ago, so there is no need for lambda sensor anymore, so my question is - is there possible to fit ECU from earlyer 2.0i pinto without CAT (N4A it was, I think). I know, that it isn't direct fit, but what i wan't to know is that is there needed any other wiring to N4A ecu? Or i just can change pins in ecu plugs and plug older ecu in? Also maybe someone have pinouts/wiring diagrams for 2.0i pinto CAT and for usual 2.0i pinto?
Old 08-11-2011, 09:44 AM
oldford
oldford's Avatar
A new Lambda sensor may be cheaper than another ecu.
It is certainly a lot easier to fit and a lot less work and worries.
Old 08-11-2011, 10:16 AM
Martinss
Martinss's Avatar
I have spare ecu from N4A, thats why it will not be cheapier to buy a new lambda.
Old 08-11-2011, 02:33 PM
Martinss
Martinss's Avatar
Any help about pinout?
3doorcozmess
31-08-2015 05:15 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
pegaz
12-08-2015 07:30 AM
Vincereese
11-08-2015 08:44 AM
09-08-2015 07:03 PM
Quick Reply: Ford Sierra 2.0i pinto ECU difference (N4B and N4A)
