water pump help
water pump help
hi all i am a new 4x4 saff owner and the past week a real grinding dry noise has been coming from engine , ive pin pointed the noise to the front of engine area as to the right of the alternator and up by the top cam pulleys , after reading a few post on here i think it coulld be the water pump bearings , is there anyway i can diagnose this for sure , and is the water pump a hard job to do (replace) ??
thanks
thanks
Cornish Fasty
one way is pop off the alternator belts, and quickly run the engine. if the noise is gone, it may well be the pump. you can give it a spin by hand then, too
pump itself isn't hard to do
Mark RS
12-10-2015 06:01 AM
