cossie wont fire up??? help
Old 08-09-2011, 10:07 PM
DAN400
DAN400's Avatar
Default cossie wont fire up??? help
just got my new engine fitted and cant get fecker to fire up,
i got spark and fuel, checked timing etc all is in order
could the old map in my autronic ecu be that far out that its stopping it from fireing up?
Old 09-09-2011, 11:57 AM
charlie luciano
charlie luciano's Avatar
I had trouble with my car once when it came to starting up, turned out to be the water temp sensor wiring, check there and make sure wiring is ok and plug is actually connected to the sensor
Luciano
Old 09-09-2011, 12:35 PM
DAN400
DAN400's Avatar
cheers i ll check that once i get home
Old 09-09-2011, 12:47 PM
R5COS
R5COS's Avatar
Have you a good engine earth ?
Old 09-09-2011, 02:47 PM
DAN400
DAN400's Avatar
yes , just the same earths as before when the old engine was in it,but will remove and clean them just to be sure
checked the sensor on back off the head, looks fine as does the plug
running out off options, anyone think its maybe the map?
tbh i think it should still fire up
Old 09-09-2011, 03:16 PM
Mark Shead
Mark Shead's Avatar
You have prob connected the crank sensor to the cam sensor, swap them around.
Mark
Old 09-09-2011, 03:41 PM
DAN400
DAN400's Avatar
Mark
nope, double checked that mark, would it have anything to do with the phase sensor not set correctly, the gap is just as it was with the last engine, but maybe when i put the dizzy back in its not lined up correctly?
Old 09-09-2011, 04:32 PM
Mark Shead
Mark Shead's Avatar
Time it up as stock car.
Mark
Old 11-09-2011, 04:35 PM
DAN400
DAN400's Avatar
its alive
got it up and running yesterday at last,
massive thanks to certain mr shead for his advise
Old 11-09-2011, 09:53 PM
v man
Zee Germans are coming
v man's Avatar
sheedy is the man
DixieTheKid
11
06-06-2020 11:20 AM
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: cossie wont fire up??? help
