cosworth running probs
#41
And as i told you last again get them plugs out that way the motor will spin over faster / will not wet the plugs / battery will last longer . and last night you said you was using a fag packet to do your gaping please tell me you was kidding . Plus why Did you change your user name from ( MARK NEEDS HELP )
#42
I didnt change my name mate. I forgot my password and had 2 reset it thru email. And passion changed my name lol. Thanx 4 all ur help guys .
Iv just tried cranking it with my spare crank sensor pluged in loose and it gives me a 1-3 code. So im quite certain its recieving pulses. Which only leaves me the ignition amp. my two r old so I need to try a diff 1. N I think itl start.
#47
All dun :-D :-D :-D. Big thanks 2 Ian. He lent me loads of bits 2 try. An after all of that it was his group a coil that got it working.!!!!!
Does that mean iv just been given a doggy coil??????? Any way THANX COLEY :-D
