YB engine rebuild diary w/Pics
#202
loom / ECU / new chip etc... is now all back together
Popping down to get my cylinder head off my brother shortly and got a 4 day weekend comming up so should have her back together and running before next week!
#203
Got me head rebuilt up the shed lastnight and diddnt get in the house till gone 11.00
Today ive been busy outside and pretty much got the car back together...
Just got a few odd bits to do tomorrow to finish her off
Quite a bit done but hopefully the pictures will do the talking, im 99% sure she'll be runing tomorrow
#205
hehe! stuck it up like that so it was out of the way and diddnt catch on anything,
Anyone who knows me wouldnt be surprised if i try to start the car like that lol...
ive had to write a 'to do' list as ill spend ages on tidying things up and miss something really important and obveous
#207
she doesnt come out very often to be honest, hoped to have her back on the road today but somewhere along the line ive lost the cambelt tensioner...
Should be ready tomorrow hopefully
my brother knows a guy who we call 'jonny bravo' who drives a V6 powered cosworth replica, when i first saw your name i thought you were him until i saw your location
#208
got a question which is open to all
The inlet side of the block theres an oil seperator which then originally goes back to the airbox and another smaller pipe connects to the inlet plenum,
since removing the airbox ive done away with the pipe that goes to the airbox but what im wanting to acheive is to get rid of the whole lot and simply have one pipe going from the oil seperator to the oil catch tank and to blank off the connector on the inlet plenum (i think its a one way valve anyway)
is this possible and will i encounter any problems?
#209
#211
Got her running thismorning but cant quite seem to get the timing right
The whole car shakes and its very lumpy
ive tried time and time again but im getting nowhere so may have to get someone else to take a look
#213
...ok before i begin i accept any piss taking that i rightly deserve, i had 2 T leads the wrong way around lol
Im just very relieved that it was a minor error on my part and not something major with any of the internals
She has a few issues which she suffered previously like occasional funny idling and slight revving now and again on its own accord (mainly when im comming to a stop but very occasional)
She goes extremely well and im very happy, just need to wait for my next bit of time off work so we can go on a long run to bed her in before the thrashing begins
#216
been on 30 mile round trip and she hasnt missed a beat
only problem is whenever i come to a stop she revs up to 2k and drops back off, does this about 5 times then levels out and idles properly
Only other thing is that after the trip i checked the oil and it was on minimum (dont fear as i was watching the oil pressure gauge like a hawk on rat)
Its not leaking anywhere so my guess is that after priming the engine i lost a fair bit filling the oil galleries, hydraulic lifters, oil filter etc... to be honest i should have checked this before setting off
But in general a very smooth run
#218
As for the idling fault could possibly be crap in the iscv, not sure about YB ones but the Vauxhall ones are very common for that fault, best bet it to remove it and clean it up with some brake cleaner.
#220
Did you reset the base idle and co% etc. As said its like the Idle valve is sticking a little but best to get all the base settings done first. Mine was doin similar lately, but my thermostat is knackered and sticks open on a run making the engine cool too much and then it starts fast idleing until it heats up again.
cossies
cossies
#222
Well with you rebuilding the engine and cleaning the internals etc, the mixture and base idles settings will likely have changed. Your MSD chip will have said what the idle co% adjustment should be set to (likely around 2.5-3%). Before any of this, you need to run it up to full operating temp, disconnect the idle valve and set the idle screw under the throttle body so that it idles at around 900rpm with the valve disconnected. This will set the base idle and you can then plug the idle valve back in.
Mixture can then be adjusted to suit the chip you have. Best to start at the beginning after a fresh build IMO, if you close to MSD, well worth popping it in for a full setup.
#225
Really good write-up.
I'm considering new rings for my 2wd hence I found this article on a search.
Do you have to go under the car to take the engine out?
I'm trying to gauge where I can physically do the job on my car as space in the garage is an issue.
It would help if I didn't have to crawl under the car to remove the block.
Thanks
Thanks
Rstar_man
143
21-07-2020 12:16 AM
Wilsfoci
15
30-03-2016 11:26 PM
cossiedean84
37
02-09-2015 11:19 PM
track.focus'd
12-08-2015 06:53 PM
Zoggon
10-08-2015 11:39 AM
