sapphire 4x4 temp sender
Old 31-03-2011 | 05:33 PM
clocky280's Avatar
clocky280
Red face sapphire 4x4 temp sender
any one tell mewhere temp sender is allso where can i fit oil pressure sender please ? dont know way round yet 1st cossie!!
Old 31-03-2011 | 06:47 PM
OAP Pete's Avatar
OAP Pete
Default OAP Pete
Yes..Temp sensor for the Gauge is on the Inlet side of Head right at the back... Just 1 Terminal hear...right next door to it is the Temperature sensor for the ECU,...2 Terminals. Moving forward on the block [still inlet side] is the Oil pressure switch plus the take off for the Turbo oil feed.
Old 31-03-2011 | 06:53 PM
clocky280's Avatar
clocky280
is the temp one behind oilfilter thanx
Old 31-03-2011 | 08:21 PM
The temp sender for the GAUGE is where said, it has a single wire connector, next to it will be a blue 2 pin plug connector, for the ECU temp sender, there is also a 16mm bore pipe there from the matrix output to the head, these are on the head tucked behind the dipstick tube are.
Rearwards of the oil filter is the oil PRESSURE switch, ie the on/ff switch for the oil light in the dash clocks.
There will be NO OIL SUPPLY PIPE HERE, as that is only on 2wd versions, your 4wd has a pipe that goes from the oil gallery on the exhaust side of the head to the turbo.
You will just have a sensor/switch in the block on the 4wd, this can be taken out and a "T" piece put in place, so that both the existing switch/sensor and the new TEMP sensor can both be put in this one place.
Old 31-03-2011 | 09:23 PM
clocky280's Avatar
clocky280
thanx alot love u all
01-11-2015 07:53 PM
Mark RS
12-10-2015 07:01 AM
Iain Mac
30-09-2015 10:39 PM
Fil
30-09-2015 01:08 PM
