044 bosch fuel pump
Old 14-02-2011 | 12:56 AM
rs2klee's Avatar
rs2klee
K***LMT
Default 044 bosch fuel pump
hi all just wanted to ask about these 044 fuel pumps!
I have 2wd on stage 3 with the normal fuel pump would it be wise to upgrade to an 044 pump of leave it alone?
also would you trust a 2nd hand one? I been offered one for £70 with the fitting kit thats not even done 1000 miles. Im lead to think that they are bullet proof as they are used in rally cars and run duel pumps..
Any info greatfull
Old 14-02-2011 | 05:48 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
u dont "need" a 044,but for £70 u might aswell get one....also "search" some threads on here about re-wiring ur fuel pump as this make a lot of difference even if u keep the std pump
Old 14-02-2011 | 06:21 AM
R5FORD's Avatar
R5FORD
There not bullit proof.. I had one that was brand new and after a few k's thr internals perished which could have blocked the feed etc but worthwile upgrading
Old 14-02-2011 | 06:52 AM
As said they are far from bullet proof, it could be wrecked in 1000 miles easy, if it's dragged in some crap from inside the tank.
There is amazingly little difference in output of the 044(group a) over the std 941 pump, it's just the lockout pressure is much better on the 044.
The std 941 pump is certainly well up to 380bhp.
The importance of a pump rewire cannot be overstated, although when testing the circuit you may well get 12v with the car idling, it could well drop to 8-9 volts under load due to old wiring not carrying enough current(amps), this could destroy an engine so needs doing(as do the fans).
Old 16-02-2011 | 05:42 PM
cossie362's Avatar
cossie362
what cable is best used to re wire the fuel pump guys?
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
15
07-10-2015 03:43 PM
wheelwizardrefurbs
18-09-2015 02:39 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: 044 bosch fuel pump
