What power?
Old 13-02-2011 | 03:10 PM
BIL N KEL's Avatar
BIL N KEL
Default What power?
T34.48 32psi
greys
standard head
Bd14 inlet cam
Standard compression
Wrc gasket
Long studded 200block
Grp A pump
What power roughly would this spec make?
If the housing was changed for .63 what difference would this make to power and drivability
Thanks Billy
Old 13-02-2011 | 04:38 PM
bad boy rs's Avatar
bad boy rs
Very punchy set up this should see 360-70
Old 13-02-2011 | 05:03 PM
Staffi's Avatar
Staffi
Billy, as said, you've got a nice quick punchy road spec there, the .63 will give you more top end power, but will be a tad more lag, your call bud...
Old 13-02-2011 | 06:19 PM
With the .63 power will come in with more of a punch later on, this is at the expense of LOST power lower down, 32psi, I'd seriously reconsider upping the turbo size for long life.
Although you cam make the power I'd seriously consider some porting, even having the exhausts ports cleaned up will bring the power in a lot lower and harder, and also help the top end, but not 100% essential.
Old 14-02-2011 | 09:41 AM
rsmark86's Avatar
rsmark86
as above i would look at porting , its the best mod that could be done to that spec
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
phil51
Ford Focus Diesel
02-10-2015 02:00 PM
Iain Mac
30-09-2015 10:39 PM
dojj
29-09-2015 11:32 PM
deathrider666
28-09-2015 07:12 PM
