steering rack leaking oil,prop uj where from?
hi,got a spare rack which im going to put on it seems all nice and tight but its leaking oil from behind the gaiter,
is it just needing seals?
where can i get them from?
is it hard to replace them?
also needing front prop uj as not been done for a while,wheres best place to get one?
thanks guys
colin
thanks guys
colin
The piccie is a manual rack not power rack, there are seals in the power rack, tbh by the time they are worn so are the surfaces on which they bear most of the time, might strip it down to find it's scored to buggery, might be better to just swap out, but seal wise easy enough.
NO should be bone dry in the gaiters, but they might be 20+ years old, if no amount to worry about, ie not dripping or needing constant topping up leave alone.
Seals are easy to get, and in better materials generally than were used 20+ years ago, a seal supplier one in most big cities, I use ALLSEALS in Norwich Norfolk.
timsrs
22
24-09-2015 08:14 PM
