secs monitor readings
hi
ive got a 2wd saff cos that is fitted with a secs monitor and every now and then i get some random info flashing up on the screen saying that the temps top high and map faulty this is mainly after some hard right foot driving.
all sensors and map have been changed, but still the same
dash temp gauge just sits above half way
what can be causing this?
any help would be great
cheers
mark
cheers
mark
Check the connection at the back of the lcd screen
Mine kept throwing up random errors, had a chat with simon
Just simply unpluging and pluging the lead back in solved the errors
avid-fan
that could be the problem as who ever fitted it has left bugger all wire betwen the screen and ecu connector.
have you got contact details for simon, so i can try and get a longer lead
cheers
mark
cheers
mark
It's just a case of fingers cut to fuck doing the job
But a tight fit to insert back in
07-10-2015 01:56 PM
