sierra cosworth abs
Old 29-07-2010 | 09:37 PM
johnyjn's Avatar
johnyjn
Default sierra cosworth abs
Does anybody know if there is any difference between a 3dr abs ecu and a 2wd saff abs ecu . If so what.Many thanks all.
Old 31-07-2010 | 12:50 PM
johnyjn's Avatar
johnyjn
Also need some wiring diagram with pin numbers for the abs.Many thanks
Old 31-07-2010 | 05:21 PM
I think but by no means sure the wiring diagram can be got from the turbosport site, the abs ecu is a different part number, but essentially the same right down to the wiring.
Old 31-07-2010 | 05:29 PM
martysmartie's Avatar
martysmartie
I am 99.9% sure it's the same to.
Martin
Old 01-08-2010 | 09:10 AM
johnyjn's Avatar
johnyjn
Thanks,i can see that the 3dr abc ecu plug has one wire in a different place to the 2wd saff unit but not sure what the wire is.Really could do with a wiring diagram for 3dr and saff looms.
3dr cossie
11
21-12-2015 04:38 PM
wheelwizardrefurbs
23-09-2015 10:14 PM
charliecosworth
19-08-2015 03:00 PM
cossie4x4
14-08-2015 07:29 PM
155lee
14-08-2015 12:21 PM
Quick Reply: sierra cosworth abs
