fireing order on 2wd sapphire
Can never remember this without looking at one, you can cheat TDC engine take off cap look at rotor arm and see what position it's at this will be number one and the next one in rotation of rotor arm will be 3. If not ill have a look for you tomorrow, someone will have probably answered for you then.
Martin
Martin
competant bodger
take dizzy cap off and look at the dizzy it has a mark on it on the side of the body turn the engine by hand until the rotor arm is central to this mark, that is position 1 i think if you are looking at the dizzy from the fvront of the car number 1 is the nearest to you on the right
Cyl 1 nearest water pump/front 4 nearest bulkhead, dizzy cap numbered from engine 4/2/1/3 so 4 nearest engine, with cap pointing reawards, no 3 nearest the nearside inner wing, king lead is between 2 and 1 lower down a bit.
Tony W
09-09-2015 12:08 PM
