Cosworth stem oil seal
Old 18-04-2010 | 06:31 PM
mattman1234's Avatar
mattman1234
Default Cosworth stem oil seal
What are the best valve stem oil seals to get,rebuilt my engine 1500 miles ago,and the seals are p*****g oil past,the plenum was full of oil(well it wasn't full but had a lot of oil in it).It had new guides,and seals.the exhaust side was leaking to.Also ive been told can re use wrc steel head gasket and long studs,is this true.
thanks matt
Old 18-04-2010 | 07:15 PM
LHD220Turbo's Avatar
LHD220Turbo
matt lewis motorsport sells the decent ones; i "think" ford still stock them too
Matt Lewis Motorsport - Cosworth & RS Parts Specialist-Worldwide Mailorder.
Walsall - West Midlands - WS4 1RR
Tel;01922 692424 - 07910818110 - Fax; 01922 685810
Genuine Trade Enquiries Welcome
http://stores.shop.ebay.co.uk/Matt-Lewis-Motorsport
Old 18-04-2010 | 07:28 PM
mattman1234
will look them up now
Old 18-04-2010 | 07:36 PM
LHD220Turbo
http://cgi.ebay.co.uk/RS-Cosworth-Ge...item2a023a47d1
Old 18-04-2010 | 07:51 PM
martysmartie's Avatar
martysmartie
Theres a guy on here who swears by Viton seals, claiming to be better than the standard Ford ones.
Martin
Old 18-04-2010 | 07:57 PM
mattman1234
All the ones i used were green,for the exhaust and inlet,and yes they were different sizes before anyone says i used the wrong ones.
Old 18-04-2010 | 08:10 PM
LHD220Turbo
Martin
that'll be tabetha, i have no experience of those seals but i've used the ones i've posted with excellent results
Old 18-04-2010 | 08:29 PM
mattman1234
i shall be ordering those before the nights out,if i get no other recomendations
Old 18-04-2010 | 08:37 PM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
if there is oil in the plenum its difficult to see how stem seals would have caused this - may be due to split fuel pressure reg diaphram
Old 18-04-2010 | 08:54 PM
mattman1234
fuel pressure regulator ??. I can see oil running down the stems,its easy in the exhaust port as it is wet around the guide.Its the only place where oil can get in the inlet port,apart from the turbo,and thats dry .
Old 19-04-2010 | 10:15 AM
protechmotorsport's Avatar
protechmotorsport
Cosworth Specialist
Are the valve guides ok? thats the only other thing I can think of... I sell the viton seals and never had any issues with them.
Old 19-04-2010 | 12:27 PM
martysmartie
That's it did not mention his name in post though.
Martin
Old 19-04-2010 | 05:15 PM
mattman1234
yeah,had new guides put in,i have ordered the ones from matt lewis,will give those a go.Any up takes on re using the wrc headgasket,will look up the viton seals though
Old 19-04-2010 | 05:16 PM
mattman1234
have you a website
Old 19-04-2010 | 07:55 PM
mattman1234
The make of my seals are "VICTOR REINZ",if that means anything to anyone.Can you get different height stem seals,or are they all the same.Between the top of the guide and the top of the seal there is approx a 5 mm gap.Just thinking that if the seal was to high,the thinner part of the top of the valve,would go past the seal,thus letting oil in,has anyone ever come across that
Old 19-04-2010 | 08:01 PM
LHD220Turbo
Victor Reinz makes very good seals, i'm surprised you are having problems
having said that, i've never used them.
sorry i cant help with the other question
Danielbetty
28-08-2015 08:01 PM
14-08-2015 07:29 AM
st220kyle
16
14-08-2015 06:13 AM
pegaz
12-08-2015 07:30 AM
Graceland
31-07-2015 10:34 AM
Quick Reply: Cosworth stem oil seal
