cosworth problems
Old 18-04-2010 | 06:59 AM
garrett's Avatar
garrett
Default cosworth problems
Hello
I am having problems with my sapp 2wd cos
When its could there arnt really any problems but the more heat comes in the engine the bigger the problems are getting
It yust fall down everytime I get on the throttle
If I build up the throttle slowly I can yust bairley get it up my drive way
Its running good idle at 800/900 rpm
Hope someone can give me any advice
Old 18-04-2010 | 09:55 AM
Check the silly things like no conenctors etc have come off, esp the coolant temp sensor, map, tps, then check the co when hot, adjusting if necessary to whatever chip your using,
Could be the cts has gone duff, is it belching black soot when revved and sooting the plugs ?
Old 18-04-2010 | 10:49 AM
garrett's Avatar
garrett
thanks for the replay
co was verry high last time i have checked it
i have yust changed the plugs to new ones the c71
and the ones that came out of the engine seems to be very black
have tested the plug leds they where fine
changed coil, crank sensor,
i was running stage 3 but changed it back to standard to see if the problem was there
so that was the ecu, injectors and map sensor are standard now
as soon as your want to let the enigne work so you can get the reving up if your standing still but if you want to drive away its yust bluuuuuuu
like its misfiring all over the place or getting to much fuell or air
manuel boeckx
13
03-10-2015 02:29 PM
CLIVE
02-10-2015 12:58 PM
Johnsie
Ford Focus ST
08-09-2015 02:39 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
14-08-2015 07:29 AM
Quick Reply: cosworth problems
