Can MSD Launch Control be fitted to your existing chip?
Can the software be added to the chip i've already got as Martoon mapped it in January and i'm very happy with it but fancy Launch control for the up coming RWYB 1/4 Mile day at Stratford Raceway.
Cheers Rich
Cheers Rich
Launch control creates boost at a stand still at a set rpm;
Taken from MSD's website:
"Simply flick a switch and your L8 launch control or P8 Launch Control is active, all you have to do now is bury the pedal to the carpet and you will see, and hear your turbocharger come onto boost and your rev limiter activate at around 3750 rpm. Lift the clutch, disengage launch control and your away, your normal rev limiter is resumed and you are off down the road at maximum speed!
The boost depends on the spec of the engine but will likely be between 10 and 35psi whilst active."
Rich
Rich
I am sure that Stu can do that because i know who had wrote the program ...
but it will be expensive, you will pay for the transfer work from one chip to another and you will pay for the little board under the chip which will crypt it...
and after, your original tuner will not be able to change something on your chip ....
Rich
Rich
155lee
14-09-2015 07:37 PM
155lee
14-08-2015 11:21 AM
