crank position sensor 4x4
where is the location of crank position sensor sierra cosworth 4x4, any pics please?
i cant see any wire to front down part of engine.
The sensor itself can easy be removed but how do you manage to "undo" the connector? I've got small hands but it seems that i'll have to remove the inlet?
Cheers,
Mark
Cheers,
Mark
To remove the connector simply push in the sprung piece on the connector itself it will then be possible to part the male/female parts, the connectors are normally located in a small bracket affair that is bolted to the block, so 13mm ratchet spanner to untighten bracket first then connector will simply slide out.
No, the connector is white as is the wiring, it has a clip it sits in near to the oil filter the braket that holds the connector is bolted to the plenum, you have to manoeurve it out of the clip (Dont need to unbolt anything) once out the connector simply seperates so the CPS can be removed.
Martin
Martin
(Trying to replace the sensor right now)
Ok, i might be doing something wrong. Does someone have a picture of this bracket? I removed the dizzycap and rotor, right behind these are twe connectors of witch the right one is the crank connector witch will not come loose.
How do you come there with your hands and what do you unbold?
Sorry, quess i'm om crystal meth....
Best pic I could find on google, can you see the white bit to the right and down from the bottom of the distributor? It is really easy to get this unplugged and out of the bracket, maybe you could get someone to give you a hand, it is a bit tight but it's by no means impossible. Have you tried it from underneath, just use a big inspection lamp to see what your doing.
DixieTheKid
11
06-06-2020 11:20 AM
mike elsome
14-09-2015 04:08 PM
