how to abjust fuel pressure
how can i abjust fuel pressurre from regulator.
i connect gauge to see the pressure and it si 3.8 bar without pipe.
i should down pressure to 3.5 bar without pipe from regulator.
can i abjust pressure on cold engine, and i should abjust bolt at the top of regulator.What direction is down the pressure clockside or anti clock side ?
The engine needs to be idling at the correct speed, so in all probability a warm engine.
Turn the screw counter cockwise to lessen the pressure, clockwise of course then to increase, don't worry about turning it they are not sensitive and will need a noticeable turn.
At idle/tickover you can't do any damage, so adjust away, just be sure to plug the end of the vac pipe with a bolt etc that you remove from the pressure reg.
SMILER258
28-09-2015 09:04 AM
