has anyone used the r+b motorsport clutch ratchet conversion (manual adjustment)? as my plastic one has shit itself with the ap heavy duty cover i have along with the pedal box breaking
cheers joe
they are expensive arnt they? and you have to remove gearbox i believe?? the heavy pedal isnt a problem mate just want the thing to work right i hate clutch ratchets
yeah gearbox out but your clutches will last longer and the light pedal is great
bad enough doing my own stuff, let alone anyone elses!
fair comment.
i had a closer look last nite and saw that the clutch pedal assembly bracket is shagged and letting the quadrant spin when pedal is raised. seat out time and on my back
out of interest you can run a standard ford thrust bearing with an ap organic clutch and cover cant you?
