I think i read on here that somebody has found replacements for these? They are the 3 mounts on the pump cradle that perish over time?
Anyone know where i can get these?
the best solution is from opel VAUXHALL but have 8mm bolt than ford 6mm and it is 5mm longer,but it's easy to fit with bigger holes,so it's geniune part and closer to ford!!!
These are VERY similar to the mountings for a Landrover Defender fan cowling rubber which connects the shroud to the engine....sorry don't have a picture at present.
Do you havea part number mate? When i checked i was told none of the parts from the fuel pump bracket were availible
Right then part number is 6167524 they are around Ł16 each,bloody expensive,u need 3 as u say above.I have a spare new set here but am keeping hold of them.
I hope this helps.
MANY THANKS.Lee.
no mate,they make the same work, they are from opel vauxhall for fuel pump,and the point is are the same as genuine maybe better because has soft rubber and it absorbs all the vibrations not like imitation rubbish
