Stage 1 MSD chip what actuator?
Old 27-12-2009 | 09:35 PM
ianbobo's Avatar
ianbobo
oohmamama
Default Stage 1 MSD chip what actuator?
Is it a requirement to change standard actuator on T3 (sapphy 4x4) to -31 when upgrading to stage 1 MSD L8 chip?
Thanks
All the best for the new year 2010
Old 27-12-2009 | 09:36 PM
KSA-Cossie's Avatar
KSA-Cossie
Don't know but i would as they're not expensive.
Old 27-12-2009 | 09:51 PM
ianbobo's Avatar
ianbobo
oohmamama
Ok, but will a -31 cause any difference as compared to a standard actuator?
Old 27-12-2009 | 10:02 PM
cossiejsy's Avatar
cossiejsy
you have to change the actuator for a -31 its gives you more boost over the standard one
Old 27-12-2009 | 10:21 PM
ianbobo's Avatar
ianbobo
oohmamama
Correct me if I'm wrong but doesn't the new chip (map) through the amal valve control the ammount of boost??
Old 27-12-2009 | 10:23 PM
English's Avatar
English
Click on this link which explains why you need the new actuator: http://www.motorsport-developments.co.uk/actuators.html
As it's a Motorsport Developments chip, you can check on the same site for what is required to run your chip. Or you can call them to find the same info.
Old 27-12-2009 | 10:35 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
if u've got a new std actuator it will be good enough........if ur setting the car up urself and have a boost guage then u'll be able to tell if its holding boost.....if not buy a -31..................
Old 27-12-2009 | 10:38 PM
pete mcrash
....ur "jetted" amal valve and ur actuator
Old 27-12-2009 | 11:10 PM
bad boy rs's Avatar
bad boy rs
had a -31 when mine was pe stage 1
Old 27-12-2009 | 11:21 PM
ianbobo's Avatar
ianbobo
oohmamama
I do have a boost gauge fitted and working, so I can check my standard actuator performance. What do you exactly mean by holding boost on a standard engine on a standard chip? Should the 10 psi boost pressure hold for as long as I maintain the same throttle opening????
Old 27-12-2009 | 11:25 PM
pete mcrash
no fella....u'll get a boost spike then it'll tail off a couple of lbs...............
Old 27-12-2009 | 11:37 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
-31 and around about half a hole of preload, std amal jetting should be ok on stg1
Old 27-12-2009 | 11:38 PM
ianbobo's Avatar
ianbobo
oohmamama
Thats exactly how the boost pressure behaves on my current standard setup, so I may safely assume that my actuator is up to the job and proceed to purchase the MSD chip only and then again watch how boost behaves then proceed accordingly as regards to the purchase of the -31?
By the way whats your opinion about the MSD stage one chip vis a vis other chips on the market??
Old 27-12-2009 | 11:44 PM
ianbobo's Avatar
ianbobo
oohmamama
'around about half a hole of preload, std amal jetting' can you please explain this . i am new to this subject
thanks
Old 27-12-2009 | 11:47 PM
JTECH James
Passion for Fords!
did the chip come with instructions?
Old 27-12-2009 | 11:53 PM
pete mcrash
......dont think he's bought it yet......
Old 27-12-2009 | 11:56 PM
JTECH James
Passion for Fords!
ahh, well if he does it will come with full instructions explaining how to achieve the boost level
ianbobo's Avatar
ianbobo
oohmamama
Have not yet bought the chip .
Old 28-12-2009 | 10:06 AM
ianbobo's Avatar
ianbobo
oohmamama
Hi mates
i want to make an informed decision before forging ahead with my upgrade.
many thanks
Old 28-12-2009 | 10:27 AM
pete mcrash
stg 1 aint really a big deal to be honest....dont get me wrong it transforms the car into what a cossie should be, but an off the shelf chip will be near enough the same off all tuners........good thing is though MSD are having a sale so deffo worth a punt....
Old 28-12-2009 | 10:30 AM
KSA-Cossie's Avatar
KSA-Cossie
As above they have a sale on just now,but just go stage 3 and be done with it.
Old 28-12-2009 | 10:31 AM
pete mcrash
where do u live fella........not being funny but as u know very little about cossies then u'd be better off getting it set up by a pro...............instead of u fookin about with it......
Old 28-12-2009 | 10:37 AM
KSA-Cossie's Avatar
KSA-Cossie
My guess is malta pete.
Old 28-12-2009 | 10:38 AM
ianbobo's Avatar
ianbobo
oohmamama
yes i know stage 1 is not a big deal but to go beyond would mean that i have to replace my T3 turbo, injectors, map sensor..... + I have read that the 4x4 g. box and transmission will not cope and therefore would be risking breaking.....
Old 28-12-2009 | 10:41 AM
KSA-Cossie's Avatar
KSA-Cossie
You'll just want more power believe me.
Old 28-12-2009 | 10:44 AM
ianbobo's Avatar
ianbobo
oohmamama
Yes I'm in Malta....not much roads where you can use all the power from robust power upgrades.....no track days just quarter miles which I am not much into
Old 28-12-2009 | 10:47 AM
pete mcrash
.....u'd get more power from ur t3....but u would need map sensor (Ł60) and bigger injectors (2nd hand greens....Ł100 tops)........and ur trans will cope with all a t3 will give......
Old 28-12-2009 | 10:56 AM
ianbobo's Avatar
ianbobo
oohmamama
What about head gasket.....its still on standard one.......and head refubishment while am at it (valve guides + followers...) the bill is rocketing
Old 28-12-2009 | 12:20 PM
pete mcrash
....how long has the gasket been on/what gasket is on it...????.....and if it aint broke dont bother.......it's upto u, it might last a day, month, year....who knows....or splash the cash and get ur head cleaned up, skimmed and a grp A gasket put on.......(i'd leave it till it blew)
Old 28-12-2009 | 12:54 PM
ianbobo's Avatar
ianbobo
oohmamama
the previous owner said it was still on factory gasket. is there a way i can verify this obviously without removing the head??? engine number starts with LM so its 1990. is it possible for gasket to last this much when properly taken care of?
Old 28-12-2009 | 01:20 PM
MannheimAlex's Avatar
MannheimAlex
I would also leave the gasket, cos it`s really annoying if you remove the head and you find an uprated one.
I am in the same situation at the moment, upgrade for stage3 and dont know what gasket is in. So wish me luck
Old 28-12-2009 | 05:48 PM
mechanic28's Avatar
mechanic28
msd chips are fine fella!!!very well known!
Old 28-12-2009 | 06:02 PM
martysmartie's Avatar
martysmartie
I think you are wise to go for stage one, I certainly would not want to go any further than this with standard HG, as standard the HG is very fragile.
Stage 1 will transform the car from what it is now mainly due to the extra torque produced.
The above gives you the most "Bang for Bucks" without buying extra hardware excluding the likes of Gunship which put you in the same boat as above with the HG.
If you look at the engine sometimes it is possible to see if a aftermarket HG is fitted you can see if it's multi layer etc.
Martin
Old 28-12-2009 | 09:40 PM
ianbobo's Avatar
ianbobo
oohmamama
Martin
I'll see if i can see any layers with some proper artificial light conditions then.
Martin because of the very limited traveling distances available over here I tend to agree with your reasoning as regards the upgrade. It is only very rarely that I am able to go over 4500 rpm in top gears and that is for very short periods of time (2-3 minutes max) due to the short suitable stretches of road available for safe driving , keeping in mind some relaxed braking distances. What would be best is plenty of torque at lower revs--short acceleration blasts
Old 28-12-2009 | 09:44 PM
ianbobo's Avatar
ianbobo
oohmamama
Good luck then
Old 29-12-2009 | 09:53 PM
opposite lock's Avatar
opposite lock
defo go to msd as in Malta think i,m right in saying that fuel is a much lower octane and im sure the are the ideal chip writers for it , just a wee thought
Old 29-12-2009 | 10:10 PM
ianbobo's Avatar
ianbobo
oohmamama
This is the analysis results for the Petrol available in Malta. Which one would you use for your cossie
Lead Replacement Gasoline
Property
Units
Limits
Test Method
Minimum
Maximum
RON
97,0
EN 25164
MON
86,0
EN 25163
Lead Content
mg/l
EN 237
Manganese Content
mg/l
18
Density (at 15oC)
kg/m3
720
775
EN ISO 3675
EN ISO 12185
Sulphur content
mg/kg
50
EN ISO 14596
EN ISO 8754
EN 24260
Oxidation Stability
minutes
360
EN ISO 7536
Existing gum content (solvent washed)
mg/100 ml
EN ISO 6246
Copper strip corrosion (3h at 50oC)
rating
class 1
EN ISO 2160
Appearance
clear and bright
visual inspection
Hydrocarbon type content
- olefins
- aromatics
% (V/V)
18,0
42,0
ASTM D 1319
ASTM D 1319
Benzene content
%(V/V)
1,0
EN 12177
EN 238
Oxygen content
%(m/m)
2,7
EN 1601
EN 13132
Oxygenates content
-methanol
-ethanol
-iso-propyl alcolhol
-iso-butyl alcohol
-tert-butyl alcohol
-ethers (5 or more C-atoms)
-other oxygenates
% (V/V)
EN 1601
EN 13132
Volatility
Property
Units
Limits
Test method
Summer
(1/05 – 30/09)
Winter
(1/10 – 30/04)
Min.
Max.
Min.
Max.
Vapour Pressure, VP
kPa
45,0
60,0
50,0
80,0
EN 13016-1
(DVPE)
%evaporated at 70oC, E70
%(V/V)
20,0
48,0
22,0
50,0
EN ISO 3405
% evaporated at 100oC, E100
%(V/V)
46,0
71,0
46,0
71,0
EN ISO 3405
% evaporated at 150oC, E150
%(V/V)
75,0
75,0
EN ISO 3405
Final Boiling Point, FBP
oC
210
210
EN ISO 3405
Distillation residue
%(V/V)
EN ISO 3405
Premium Unleaded Gasoline (EN 228)
Property
Units
Limits
Test Method
Minimum
Maximum
RON
95,0
EN 25164
MON
85,0
EN 25163
Lead Content
mg/l
EN 237
Density (at 15oC)
kg/m3
720
775
EN ISO 3675
EN ISO 12185
Sulphur content
mg/kg
50
EN ISO 14596
EN ISO 8754
EN 24260
Oxidation Stability
minutes
360
EN ISO 7536
mg/100 ml
EN ISO 6246
rating
class 1
EN ISO 2160
Appearance
clear and bright
visual inspection
Colour
undyed
visual inspection
- olefins
- aromatics
% (V/V)
18,0
35,0
ASTM D 1319
ASTM D 1319
Benzene content
%(V/V)
1,0
EN 12177
EN 238
Oxygen content
%(m/m)
2,7
EN 1601
EN 13132
Oxygenates content
-methanol
-ethanol
-iso-butyl alcohol
-tert-butyl alcohol
-other oxygenates
% (V/V)
EN 1601
EN 13132
Volatility
Property
Units
Limits
Test method
Summer
(1/05 – 30/09)
Winter
(1/10 – 30/04)
Min.
Max.
Min.
Max.
Vapour Pressure, VP
kPa
45,0
60,0
50,0
80,0
EN 13016-1
(DVPE)
%(V/V)
20,0
48,0
22,0
50,0
EN ISO 3405
%(V/V)
46,0
71,0
46,0
71,0
EN ISO 3405
%(V/V)
75,0
75,0
EN ISO 3405
oC
210
210
EN ISO 3405
%(V/V)
EN ISO 3405
Old 29-12-2009 | 10:52 PM
ianbobo's Avatar
ianbobo
oohmamama
Trying to present the fuel analysis in better format:
Old 29-12-2009 | 11:05 PM
pete mcrash
the highest octane.........97ron.................
Old 29-12-2009 | 11:29 PM
ianbobo's Avatar
ianbobo
oohmamama
97 RON LRP has got manganese content at 18 mg/ltr minimum is that good for the yb engine?
