Fuel pump
Fuel pump
Could someone please recommend what type of fuel pump i could use for my 86 3 dr totally standard no mods at all its been standing a while, cant get it pump up at all, local ford parts want £190 +vat for a standard one,cheaper is there one available and where, many thanks
For this spec a std pump is fine, more than enough, contact Matt Lewis, it is under £100 from him, and he has them in stock normnally.
If you haven't already done so, I would suggest rewiring the fuel pump circuit, and the fan circuit.
Apply 12v to the pump direct from a battery/starter pack etc to see if it has any life as it could be something else stopping it, doesn't matter which way round the wires go on to check, as if wrong way it will just spin the other way, but show that it's working, no noise obviously dead as a dodo.
Just ask Matt Lewis for a 941 pump, the normal uprate, which you don't need is a 044, or called "group a".
Fuel pump
Had pump checked at local bosch dealer was found to be knackered but i have not got any power at the pump supplies any ideas please is there an inertia cut out on this model and where would i find the fuel pump relay many thanks
Would of suggested that when the OP was replied to but diden't bother as the car is 3DR and they never had intertia switches.
Also fuel pump relay is under dash on passenger side I think it's yellow in colour.
Martin
Martin
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
