2WD Idle screw
Old 05-12-2009 | 07:11 PM
Cosmo's Avatar
Cosmo
Default 2WD Idle screw
Has anybody got a spare 2wd idle adjustment screw or know where i can get one from?
Was messing with mine on the 3dr today and must not have tightened the retaining nut enough, its vibrated out in transit! DOH!!
If not anyone know what thread it is, or if any other fords have the same screw? (maybe get some threaded bar to fit or a nother screw from something else, even the finis code for fords etc)
I cant drive my car without one (even though its not the right weather to be driving it anyways!)
Old 05-12-2009 | 07:18 PM
mechanic28's Avatar
mechanic28
how the hell has the co2 ajustment screw fallen out?dont think that can be replaced!
Old 05-12-2009 | 07:20 PM
Cosmo's Avatar
Cosmo
Not the Co2 screw mate, the one under the throttle body that controls the base idle
Old 05-12-2009 | 07:22 PM
COLEYST200's Avatar
COLEYST200
is it not just a M5
Old 05-12-2009 | 07:30 PM
Cosmo's Avatar
Cosmo
is it not just a M5
Could be mate? Do people think that some M5 threaded bar or m5 bolt with an appropriate locking nut would do the job?
Sorry if this sounds a bit thick, apparently they do sell them at Graham goode, but they want £15 for a small screw, seems a tad expensive?
Old 05-12-2009 | 07:53 PM
RS SHAUN's Avatar
RS SHAUN
yeah just looked on graham goode 34 quid
Old 05-12-2009 | 08:09 PM
Cosmo's Avatar
Cosmo
Thats so expensive for what it is!! how they can justify £34 for a small piece of threaded bar i dont know.
Anyone got one knocking round? Bet i've had a few knocking about in my time, typical i've "de-cluttered" my garage of late! Big mistake that was!
Old 05-12-2009 | 08:24 PM
SteveB's Avatar
SteveB
GGR have probably had them made as they weren't available from Ford, you had to buy a complete throttle body (enquired a few years ago)
Old 05-12-2009 | 08:38 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
I need one too.
Old 05-12-2009 | 09:43 PM
mechanic28's Avatar
mechanic28
ah ok!might be worth contacting the breakers on here
Old 05-12-2009 | 09:50 PM
COCHYN's Avatar
COCHYN
Yup, that happened to mine too when we turned the boost up
Old 06-12-2009 | 02:14 PM
I didn't realise this falling out was so common, the price from GGR is very OTT, as not that costly to have made even as a small batch.
Not sure on the thread but assume it will be a fine thread, so shouldn't be that hard to get a bolt and file a taper on it as needed.
If you put plastiscene on the threads it will stop it vibrating loose in future.
Old 07-12-2009 | 06:15 AM
Cosmo's Avatar
Cosmo
Thats what i was thinking, dont suppose anyones got a piccie of one have they?
Old 07-12-2009 | 06:24 AM
RS SHAUN's Avatar
RS SHAUN
when i lost mine, i bought a full throttle body off ebay for a tenner!
cheers shaun
Old 07-12-2009 | 08:11 AM
COCHYN's Avatar
COCHYN
Not so much common, but simply a mistake while trying to do a lot of things at once. That kinda got forgotten
Old 07-12-2009 | 06:34 PM
Cosmo's Avatar
Cosmo
I've had a go at making my own in work today, havent had chance yet to see if it works, will get chance tomorrow, will post up how i got on
Old 09-12-2009 | 05:25 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
How did it go?
Old 09-12-2009 | 05:35 PM
RS SHAUN's Avatar
RS SHAUN
http://cgi.ebay.co.uk/cosworth-sapph...item414b46acd1
cheap enough
cheers shaun
Old 09-12-2009 | 07:59 PM
cossiejsy's Avatar
cossiejsy
graham goode have one on ebay for 4x4 for £14.95 quid plus
Old 09-12-2009 | 08:06 PM
BRAM's Avatar
BRAM
when my mate lost his he got one from msd cant remember how much though
Old 09-12-2009 | 09:37 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
2wd screw is £34 - what is the difference between the 2wd and 4wd?
Old 10-12-2009 | 06:22 AM
Cosmo's Avatar
Cosmo
Originally Posted by avinit1rs
How did it go?
Still havent had time to fit it yet, its always dark when i finally get from work Am half day friday so will give it a go then.
If it works i should start up a business making them on the cheap , sounds like i'd do well, think quite a few people have lost them
Old 10-12-2009 | 10:24 PM
cosy trav's Avatar
cosy trav
If you get stuck lee i have a 2wd throttle body in the loft somewhere .
Old 11-12-2009 | 06:17 AM
Cosmo's Avatar
Cosmo
Spot on mate i'll let you know how i get on today
Hows tricks fella? Your 3dr running ok?
Old 11-12-2009 | 06:23 AM
R5FORD's Avatar
R5FORD
Its a screw that people need thats how GGR justify the price
I paud 20quid for one from GGR only a few weeks ago.
Old 11-12-2009 | 01:22 PM
Cosmo's Avatar
Cosmo
Had a go with my "home made" screw today - unfortunately it didnt work
Thread size was way off on the one i made, had a look around the garage and through the process of elimination (and trial and error) found the thread is the same as a temperature sensor (i had an old one in one of my junk pots) However there's not enough length on that
So its looking like i'm going to have to buy the real deal at the stupidly high price at this rate
Old 11-12-2009 | 05:48 PM
cosy trav's Avatar
cosy trav
Not too bad lee , bloody clutch has gone wrong or its the thrust bearing got pedal feel but clutch wont release .
Send me your address to my works number ends in 2249 and i will post the nut too you or call around saturday night .
Old 11-12-2009 | 06:04 PM
Cosmo's Avatar
Cosmo
Nice one pal! Will drop you a txt
As for your clutch mate - i got a brand new release bearing here your welcome to pal if you want it?
fordrallycar
30-09-2015 07:57 PM
mark r
29-09-2015 07:27 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
Quick Reply: 2WD Idle screw
