...4x4 rail with 2wd fuel feed ??...
Old 06-11-2009 | 08:11 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Default ...4x4 rail with 2wd fuel feed ??...
evening folks
have got a 4x4 fuel rail to go on my 3dr is it possible and can anyone tell if it is where i can send my 4x4 fuel rail to have the 2wd end `welded` on so it looks `factory` with the 2wd end
put this end-
onto this-
cheers
Old 06-11-2009 | 10:42 PM
mechanic28's Avatar
mechanic28
where bouts are you?anywhere with silver solder should be able to do it
Old 06-11-2009 | 11:05 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
north yorkshire mate knaresborough
am i right a jeweller or a `knife maker`?? should be able to do this then?
Old 06-11-2009 | 11:34 PM
mechanic28's Avatar
mechanic28
shoud do mate as they would have it!maybe worth giving north yorks rs a shout sure he will have the solder etc
Old 07-11-2009 | 10:55 AM
Can be braized, welded(tig) or silver solder as said, this is what I'd do as it's very strong, this is what I do to the turbo banjo joints for water feed/return.
Any basic welding place should be able to do this, jewellers are not really going to be equipped for stuff this large, as have to get nice and hot.
Why not get a fitting put on for pressure sensor too ?
Old 07-11-2009 | 12:07 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
yeah will give paul a bell for the solder
theres a place round here that does amazing work with stainless,just happen to know a lad that works there ,didnt think they could do it,asking aint gonna cost me is it
would you put fitting on the end of the rail or on the pipe bud?
Old 07-11-2009 | 06:35 PM
Just do what ever is easiest/safest most convenient for you.
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
JK12
33
26-04-2021 12:09 PM
03-11-2015 04:08 PM
15
07-10-2015 03:43 PM
FlashRS
13
31-08-2015 06:02 PM
Quick Reply: ...4x4 rail with 2wd fuel feed ??...
