What should be standart gasoline pressure
What should be standart gasoline pressure on iddle on sierra cosworth 4x4
i have stage 3 spec and i dont know what pressure. Is 3 bar on iddle fine and 3.6 on fuul throttle
3 bar idle is about standard. Key on, Engine off standard is 3.5 bar.
On full throttle (and full boost) you have to add the boost to the 3.5 bar nominal pressure. So 1 bar overboost must gave 3.5+1 = 4.5 bar fuel pressure, 2 bar overboost = 5.5 bar fuel pressure.
However, you should contact the maker of the chip for the right pressure.
Why are you asking? Any problems?
SMILER258
28-09-2015 09:04 AM
Dubs44
19-09-2015 06:31 AM
