I know this is going to sound daft but when your off the throttle should the butterfly on the throttle body be completely shut? Or should it be slightly ajar?
3 Door Cossie if it makes any difference.
Cheers Rich
It's just I had the throttle body off and noticed it wasn't shut fully when closed so I adjusted it to being fully closed, butterfly is a tight fit and doesn't let anything through (checked it with brake cleaner) But now i've re fitted it the idle control valve has gone barmby tring to hold the car at 2500rpm all the time, it's fine if you unplug it. I haven't driven it on the road yet.
Rich
