18s or 17s alloys for my saff need help
looking at getting some 6 spoke comp mos in 18 what offset do i need? will they catch? got a rwd saff quite low, white,with 17 inch black evo r s wanting a refurb to b mint again so torn between wheels that look good on saphs,i do like the rs seven spokes they look good,the car had 18s on when i brought it had them removed as i caught the front drivers wing twice but seen alot of saff with 18s on what offset do i need if i get 18s and do i need to roll front n rear arch lip if i go for 18s as i said car is very low any help most appreciated thanks,,,
if you going for 18"mo,s you need an et35 offset with 215/35/18 tyres not sure if they will catch theres a few on here with them so im sure they will tell you. ive got 18" revolutions on mine with 215/35/18 tyres and the offset is et33 ive had to roll the front lips on mine also im on koni adjustables, heres a pic of it might help you make up your mind
alot of people seem to think 17s on saphs. I think 17s give the best ride but 18s look a whole let better, Its suprising that extra inch makes a difference
The saph is a big car and I think the 17s look small on them, but I can understand that they are probably the best drive.
Hi I run 8x18" Braid alloys with offset 33 and 225/35 tyres on my 2wd ...... suspention is std type with Koni/Bilstein dampers and Eibach springs and no problems until now .... and yes I have sleightly rolled arches.
I was also adviced not to go 18's...but I did it and until now I it been fine with no catching whatsoever. Car feels fine and goes just as well as on my old 17's...AND, in my opinion, it looks sooo much better
07-10-2015 12:56 PM
