How allign the cilinderhead when mounting
Hi,
How allign the cilinderhead when mounting??
Because there are no bushes to fit on.
I was using arp's before, but now a want to you us original bolts with group a.
greetz Martijn
greetz Martijn
You could just use a snug fitting wooden dowel in a hole at each end of the block, some cut the heads off some old bolts if they have them, cut a slit in it so can be unscrewed, that's if you have any old ones.
If you've still got the arp studs just temporarily screw a couple of these into the block, fit the head so it's aligned on the studs then remove them and fit the new bolts.
rsguy
44
29-09-2015 03:29 PM
DavidK
27-09-2015 02:55 PM
Andypandy260
23-09-2015 10:28 PM
