fans inop 2wd saff
Old 30-09-2009 | 06:43 PM
millsey's Avatar
millsey
Default fans inop 2wd saff
Fans were working fine. now they have just stopped working could this be the switch or the fan loom. the fans still work on my manual switch.
any help would be good
cheers dave
Old 30-09-2009 | 06:57 PM
pacwest's Avatar
pacwest
Puller of the Wrench
Test switch by sticking it in boiling water (missus' blow dryer works too) with a DVOM that has a thermistor plug (or if you own a good thermostat)
Test circuit with a DVOM. Test relay and bypass relay circuit. Check wiring for melting at the fan.
Old 01-10-2009 | 01:36 PM
As it still works when switched manually the circuit is ok, so just bridge the fan switch connector and see if it runs, if it does it is a duff switch, if not investigate further.
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
cossie330
27-09-2015 05:13 PM
DavidK
27-09-2015 03:55 PM
ajamesc
27-09-2015 03:25 PM
Russ Payne
25-09-2015 09:29 PM
